Old 03-18-2008, 10:56 AM   #1 (permalink)
coolblackser
Wiring in FB13 Sunny turn signals?
The 93 sunny turn signal has a black and green/yellow stripe "2 wires". My classic 93 has 3 wires. What do i do? How do I wire it? Thanks for the help
93' White SE-R. B14 wheels, sunny turn signals, tsuru taillights, NX2000 brake upgrade, Axxiss ultimates...
coolblackser is offline   Reply With Quote
Old 03-18-2008, 11:03 AM   #2 (permalink)
PuPPiesonAciD
3rd one is for the parking lights
'95 SENTRA SS SR16VE in progress TDAY edition
http://www.cardomain.com/ride/2453804 <- my sentra ^^
¿Dudas con tu nissan? Ubicame en kb_ssr@hotmail.com o al 820 93 915
PuPPiesonAciD is offline   Reply With Quote
Old 03-18-2008, 11:09 AM   #3 (permalink)
PhorB13
SR20DEviant
Trader Rating: 20 (100%)
Are you trying to rewire them? The Tsuru conversion is the same, it has 2 wires and my Classic has 3. What I did was I shaved the bulb carrier itself on my Classic. It has either one more or one less spline on it, so what you have to do is shave them down to they are level and flat. ALL EXCEPT THE WIDEST, MOST RECTANGULAR ONE. Then you can slide in your stock B13 corner light carrier into the Sunny/Tsuru lense itself. This will give the corners the same functionality as before. As parking lights and as turn signals.
Originally Posted by Serban View Post
1991 SE-R -- Hot Shot intake w/ Pop charger, Megan cat-back exhaust, SSAC headers, JWT S4 cams, 2000 SE disc, ACT HD pressure plate, B&M shifter, ADV22 brakes w/ SS lines, FSTB & RSTB, ES sway bar bushings F/R, & Prothanes. Boost soon to follow
PhorB13 is offline   Reply With Quote
Old 03-18-2008, 11:29 AM   #4 (permalink)
coolblackser
thanks i didnt want to rewire the harness, does your bulb stay in after you shaved off those extra tabs?
