Old 03-22-2008, 08:44 PM   #1 (permalink)
need help with my ve swap!!
did a ve swap got everything hooked up and in. Car turns over, fuel pump works, all the lights in the dash everything works, but no spark at spark plugs. Changed the coil and still no spark. Put new distributor, plugs, plug wires, cap, rotor, ect... I have been chasing wires and tring to figuer this out for 2 weeks now. I'm out of ideas and thoughts.
I'm not getting the single from the ECU to the distriutor moduler. Please let me know what your thoughts are.
jpshumway is offline   Reply With Quote
Old 03-22-2008, 08:51 PM   #2 (permalink)
Check your plugs. 02 sensor and the igniter plugs are identical. If you have them backwards you will get no spark and you can potentially blow your ecu.
I had that problem, luckily Dre caught it before i hurt anything. I would tell you the wire colors now but i am 1000miles away from my baby...sorry.
GL.
Dudeman
91 ve
Current: 3inch vrs/ws2, ssac, n1's,b14tranny, lm-1,calum realtime, n60maf,shortened konis/gc's, nx brakes, shortshifter, fstb, progress rearsway, solid mounts.
