Old 03-30-2008, 11:20 PM   #1 (permalink)
bait
Is there any way to get 6.5in comps into an NX2000?
I picked up a great deal on a set of 6.5" components... I was wondering if there was any way to get them into my nx or if I just shouldnt bother.
bait is offline   Reply With Quote
Old 03-30-2008, 11:54 PM   #2 (permalink)
TommyD241
SR20 apprentice
I'm fairly sure that you can fit some 6.5" drivers into a NX with a little bit of modification but I don't own one so hopefully some NX owners will chime in.
98 Sentra SE: Injen - SSAC - Magnaflow - Stillen - Elemental Designs - Kenwood
Old 03-31-2008, 01:07 AM   #3 (permalink)
Nitelife
Nitelife's Avatar
Trader Rating: 20 (100%)
You can fit them. Some people have used the 4x6 stock plate as a mounting surface by cutting out the stock speaker and screwing the 6.5 into the plate. I think you can fit just shy of 2" deep speakers in the stock location, otherwise you will need to use MDF spacers. I went a bit ghetto and mounted my speakers to the door panel beneath the grill/map pocket section which runs along the bottom of the doors. This is a separate piece from the rest of the door panel.
Nitelife is online now   Reply With Quote
Old 03-31-2008, 05:02 PM   #4 (permalink)
tearoff guy
Nx is my drug addiction
tearoff guy's Avatar
you should really look through some of the threads and research this out,, this topic has come up oohhhhh 4 or 5 times in the past yr.. LOL ..
the answer to your question is YES you can put 6.5 comps in your door. you will need to use a small spacer and depending on the name brand of speaker you might have to trim just a little off the door (at the speaker)(grill).. heres a pic of Boston Acoustic's in my door.. hope this helps you
1991 Nx1600 hardtop 2.0 swap BC Stroker project for 2008
1992 Nx2000 my wake up call
JWTpopcharger,SSAC2.5 header/down pipe VRS CATBACK/Magnaflow,KYB AGX-Hyperco Gen II's,F1 stage3 clutch/flywheel,ES/Prothane motor/tranny mounts, R1 concept front/rear drilled/slotted rotors,AXXIS pads,clear side markers,Maxxim/wheels/205/40/16NittoNeoGens,RedlineMT90,Mobile1,Fstb
tearoff guy is offline   Reply With Quote
