Old 04-01-2008, 04:00 PM   #1 (permalink)
ser91
Nismo King
cluster is dead! argh!
i searched through 8 pages of search results and cant find anything... i was randomly driving my car 2 nights ago and the cluster just stopped working. the tach droppped all the way to the bottom and the gas gauge didnt move when i put $20 in the tank, and the damn temp gauge doesnt work wither. the speedo never hasnt worked for years because of the speed sensor. and no idiot lights either. what could cause this? and what can i do to fix this? please let me know... any advice would help tons. thanks
-Sam
91 White Se-r|I/H/E/nx2k brakes/eibachs/gr-2s/soon gti-r powered|14.5@94
92 Slate Grey Se-r|bone stock/100k/Zero Rust
94.5 Aztec Red Se-r|SSAC header/Megan Catback/JWT ECU/Hyperco springs/AGXs/ST f/r sways/ST bushings/Stillen FSTB/nx2k brakes/SE-Ls with 615s/VE POWERED
94 Blue G20T|mint interior/80k/zero rust/ve soon
93 Dakota|250k and counting/5 speed/studded tires/winter beater
ser91 is offline   Reply With Quote
Old 04-11-2008, 01:07 PM   #2 (permalink)
SOUTH TEX SE-R
I had a similiar problem with my '97 SE-R. The only thing was that my car's cluster would randomly start working while driving. I also had a second issue where the car would not crank over when ever it was warm outside. It would start fine after letting the windows down and the interior cooled off or if I parked it in the garage. I ended up replacing the ignition switch and both problems went away. Again, I am not sure if it will fix your cluster issue, but it did for me.
1997 200SX SE-R
2007 F150 LARIAT
2006 NINJA ZX6R 636
www.jgarza4.qhealthzone.com
SOUTH TEX SE-R is offline   Reply With Quote
Old 04-11-2008, 09:19 PM   #3 (permalink)
nismo94tuner
Something in the works...
Trader Rating: 46 (100%)
Check the main fusible link coming off of the positive terminal on the battery. I know when mine blew all of my dash lights/cluster went dead.
-Bes
92 Sentra
----BNB----
Squaddd up
Old 04-12-2008, 12:05 AM   #4 (permalink)
ScottNotBombs
Check the meter fuse under your dash, the very bottom one on the right side of the fuse block. I did the same thing when I touched the positive wire to my neutral switch on my trans, shorting it.
ScottNotBombs is offline   Reply With Quote
