Old 04-27-2008, 01:36 PM   #1 (permalink)
spoogy
carholic
Help with halo wiring plzz
Ok so I searched and searched but it was in vain so please forgive me if there was already an explanation for this..
Its the halos (they say 95-99) that is going into a 1995 200sx se-r
Ok so in the first picture
A=> I need help with this as I do not know where this plug goes to???
B=> Ground
c=> Current (12volt power supply)
http://www.freeimagehost.eu/image/50ed953031368
second pic
D=> I also need help with these two red wires as I have no idea where they go..
http://www.freeimagehost.eu/image/c7b22f3031369
so I guess my question is where does A and D go to?
Also for the ppl that have done this--if I were to get the 98 sentra honeycomb grill would that fit perfectly in the plastic grill mounts that came with the headlights with little or even no mods?
a little assistance please.. Much appreciated.
Spoogy
spoogy is offline   Reply With Quote
Old 04-28-2008, 09:45 AM   #2 (permalink)
LIUSPEED
DNE's VZR Conversion
spoogy your best option is to throw away the damn harness and pay someone that knows their electrical work to create you a new one for those harnesses are cheap and will melt and crap out on you.
as for the grill yes it will fit just fine but your better off cutting the brackets off the headlights than cutting off the metal brackets on your car itself.
LIUSPEED is online now   Reply With Quote
Old 04-28-2008, 01:13 PM   #3 (permalink)
spoogy
carholic
has anyone ever done this themselves and so have a how to on it??
or is it possible to cut the three wires from the halo plug and simply splice them into the original plug..then I would have the 2 red wires from D that came out from the headlight themselves to attach (forgive me if it sounds like rubbish but I'm quite the DIY as mechanics and electrician fees are wayy pass my budget here so I try to fix what I can myself.)
Old 05-06-2008, 04:49 AM   #4 (permalink)
spoogy
carholic
Update..
So I tried my hands at it this past weekend and it turned out great...
I cut the factory female plug and replaced it with the female plug off the halo harness..then spliced the halo wires to the park light and did the fog mod while I was at it so they both light up in park, lowbeam and highbeam..
As for the grill..I cut the plastic bracket off the headlights but still had to cut some of the metal off the bracket on the car..but in the end it was a success..
thanks yo!!
