NO power to radio!! - SR20 Forum
Old 07-11-2009, 04:05 PM   #1 (permalink)
LOW N SLOW
NO power to radio!!
ok, so i wired in a radio in my 98 sentra..worked fine til one day i wanted to change radios, so i started to take it out (just the trim panels and pulled out the radio/pocket thing/cupholder..then realized i didnt have the wiring harness for the other radio i was going to put in..so i started putting everyhting back together, now i have NO power to radio at all..and these 2 plugs appeared out of nowhere..one is a white plastic connector with 4 wires coming out, and the other is a black connector with only one wire coming out..i never saw these connectors before this, and they are spliced into the rest of the harness..which all the other wires are connected and such..i will post pics ASAP..
HELP!!
justin2386 is offline   Reply With Quote
Old 07-11-2009, 05:38 PM   #2 (permalink)
LOW N SLOW
PICS
PICS
Old 07-27-2009, 01:16 AM   #3 (permalink)
LOW N SLOW
BUMP..
..anyone?
Old 07-27-2009, 03:57 AM   #4 (permalink)
Are you plugging the antenna back in? That's how nissan radio's ground. Most of the time that's the problem, not the power.
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
Old 07-28-2009, 04:07 AM   #5 (permalink)
LOW N SLOW
i will try that in the AM..
Old 07-28-2009, 05:50 AM   #6 (permalink)
Feedback Score: 6 reviews
What he said!
Or the other issue is if you had the ignition on while putting the radio back, you could have popped the fuse, as I've done a time or two.
fullahwickednez is offline   Reply With Quote
Old 07-28-2009, 11:57 AM   #7 (permalink)
LOW N SLOW
Originally Posted by fullahwickednez View Post
What he said!
yea, not any fuses..i checked all of them..at least twice..lol
Old 07-31-2009, 01:07 AM   #8 (permalink)
LOW N SLOW
well tried the antenna..didnt work..trying to sell the car so i need to fix it!! and i will also check ALL the fuses AGAIN in the morning..
ANY other ideas??
Old 07-31-2009, 03:59 PM   #9 (permalink)
Did you check the fuse on the back of the radio?
Old 08-01-2009, 04:40 AM   #10 (permalink)
Does your dome light work? I had this happen to me, and I noticed that he dome light wasn't on. So I checked the fuses and sure enough it was the fuse that had been blown.
essare20 is offline   Reply With Quote
Old 08-23-2009, 11:00 PM   #11 (permalink)
car toys ex installer here.
even if you plug the antenna in the radio will still ground through the iso mount brackets that you use to fasten the radio to the dash mounts.
do you have a test light, this is a very simple test to check for power. the red wire coming off the after market radio is the ignition power and the yellow one is called the constant power, use a test light and connect the alligator clip to the dash mounts then test the yellow wire circuit on the back of the radio with the ignition off then turn the ignition on and test the red one. if one desn't work then you need to check the fuses including the fuse box under the hood.
and please get some butt connectors and not electrical tape.
waynecur is offline   Reply With Quote
Old 04-25-2011, 10:31 PM   #12 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
This might be helpful if the poster is still having trouble for the past 2 years.
The community is here.
