Digital Cluster in B14.. - SR20 Forum
Old 10-18-2010, 10:33 PM   #1 (permalink)
Works great but obviously the speedo is way off... I read in the tech articles, but no one lists anything about a b14... I got a w11 motor... 5speed... I saw people were sayin to get the nx 1.6 mt speed sensor.. but it says that goes in the speedo. Where do I go from here to get my speed right
thanks
[ 96 se-r | w11 | t28 | nismo afpr | walbro 255 | safcII | aem uego | kyb agx / road magnets ]
[ act 4-puck | fidanza flywheel | 3" dp 2½" back | b&m shifter | prothane mounts ]
Slut is offline   Reply With Quote
Old 10-21-2010, 10:41 AM   #2 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
You need the 1.6 speedometer gear. It goes into the transmission.
The community is here.
Old 10-21-2010, 12:09 PM   #3 (permalink)
Feedback Score: 9 reviews
If I'm reading it correctly, his signature says '96 SE-R with a W11. That would imply that he has an SR20DET.
If that IS the case, a 1.6 speed sensor won't even fit the SR transmission.
Also, the 1.6 and 2.0 gears have the same amount of teeth (32 or 36, can't remember). I know, cause I've compared and counted them myself.
What you DO need is a speed sensor from a 91-92 NX2000, which had a digital cluster. Now, an NX2000 never had a digital cluster, however, Autozone lists a speed sensor that works perfectly:
http://www.autozone.com/autozone/par...uestid=2603158
It's the top one, or the SU4055
Buy it, install it, and your speed is dead on. Trust me, I've done the same.
The problem is the "non-digidash-speedsensors" have only half the pulses per revolution (8-9ish) than the "digidash-speedsensors" (16-18ish).
M0J0 is offline   Reply With Quote
Old 10-23-2010, 01:48 AM   #4 (permalink)
So i purchased that speed sensor.. first off the post where the gear rides on taht is 10mm the oem speed sensor is 9mm. so i got it to fit but the depth of the one is like a half inch to big. It wont sit all the way down in the tranny... do you have an oe part number i can compare it too. . It was a bitch gettin the oe one out.. the size of the sensor fts perfectly im the sr tranny just too long. What next lol?
Old 10-24-2010, 06:18 PM   #5 (permalink)
Did you get the correct sensor? Did you compare it to the stock sensor? If you have an SR, I think you might have gotten the GA sensor. Which is indeed quite a bit longer.
