Wiring resistor for EGR Temp sensor - Page 3 - SR20 Forum
Old 08-21-2009, 06:56 PM   #41 (permalink)
SR powered
Feedback Score: 5 reviews
68K worked for me.
DreSEL is offline   Reply With Quote
Old 08-21-2009, 10:25 PM   #42 (permalink)
VE 96 SE-R
Feedback Score: 18 reviews
Originally Posted by DreSEL View Post
68K worked for me.
do you know what wattage it is?
Robert Sousa
SR20DEEP CA
http://i17.photobucket.com/albums/b5...IMGP5288-2.jpg
96 SE-R VE goodness
95 G20, VE super stock DD
SER96VPEC is offline   Reply With Quote
Old 08-23-2009, 06:21 PM   #43 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
The color code on mine is brown(space)red green yellow gold and the body is blue. I want to say it's a 1/4 watt resistor.
The community is here.
Old 08-23-2009, 07:37 PM   #44 (permalink)
VE 96 SE-R
I probably have the wrong resistor. Body is beige, color code is orange(or brownish), black, brown, gold. It's a 1/2 watt and straight 100-Ohm. I've noticed some people list values of 68K. So I need one that states 68K or 100K right?
Old 08-23-2009, 09:10 PM   #45 (permalink)
eric96ser's Avatar
The FSM says the sensor should read between 0.57 -0.70 M ohm at 122deg to .08 -.10 M ohm at 212deg. There is also a graph showing that the acceptable range is 600k to 100k ohm. A 100ohm resistor is way too low.
Old 08-23-2009, 10:37 PM   #46 (permalink)
VE 96 SE-R
Thanks for the info. I went ahead and bought the big $6 variety pack of blue bodied resistors at Radio Shack. So I should be good to go this time around.
Old 02-26-2010, 10:03 PM   #47 (permalink)
I thought I would add that I have a 93 SE-R with a DET swapped in using a stock SE-R ecu (94, cali model i believe). I was getting error 35 - EGR Temp sensor. After reading this thread I was a little confused as to what value resistor to use. Some figures were thrown around such as 100 ohm...100k ohm and 68k ohm and I would like to clarify a bit. 100 ohms is FAR different from 100k ohms - 100 does not equal 100,000(k means 1000). I don't think anyone meant to be misleading, but...it was lol.
Based on what eric said...
(I looked in the FSM for this info/graph, but could not find it.)
68k doesn't seem like enough (although it worked for someone), and 100k is right on the edge of the scale (100k resistors arent every EXACTLY 100k, even good resistors can be off by 5%) , so I decided to aim for the 200k range. I had a few 100k 1/4watt resistors, so I just put two of them in series, effectively making myself a 200k resistor. I put this across the two terminals of the EGT temp sensor connector (underneath the intake around the middle of the manifold, roundish 2 pin connector), cleared the codes from the computer and went for a drive. So far after a good half hour of driving easy, idling, and all out beating the crap out of the engine (and tires), I have no check engine light. Right now the resistors are just pushed in and holding fine - I may solder them in correctly later. Hope this helps someone in the future, I know I spent an hour or two with the wrong resistors.
newB13 is offline   Reply With Quote
Old 02-27-2010, 06:24 PM   #48 (permalink)
eric96ser's Avatar
Great info. It's rare that someone takes the time to solve and problem, instead of just ignoring the CEL.
Old 12-13-2010, 12:14 PM   #49 (permalink)
SR20DE+T FTFW!!!
Feedback Score: 6 reviews
So in conclusion a 200k ohm 1/4watt resistor is the one we should get? Correct me if im wrong people I've read a million different ohm values 68k, 100k, 200k or will any of the above work? Got a B14 turbo build with no egr so I wanna have this all set before it comes off the lift. Ordered a 200k ohm 1/4watt resistor to try out but if someone know its wont work let me know asap!
nismo4life11 is offline   Reply With Quote
Old 12-13-2010, 01:52 PM   #50 (permalink)
VE 96 SE-R
Plugging the sensor in or using the resistor has the same effect...it'll keep the CEL light off. I've done both on my B14(currently have a resistor) and I have the sensor plugged in on my DD P10.
Old 12-18-2010, 09:37 PM   #51 (permalink)
SR20DE+T FTFW!!!
well verdict is out so I thought I'd post my results on my turbo b14 with nissport egr block off plate. The 200k ohm 1/4 watt resistor in the egr connector works and no check engine light!
