Old 06-22-2004, 07:52 PM   #1 (permalink)
Audio Nut
ECU wiring question (quick disconnects for piggyback ecu)
In my case the piggyback ecu is an e-manage, not that it matters. I was curious, would it be possible to use some high quality quick disconnects so that I could remove my e-manage and still be able to run the car? I just don't want to go through the trouble of cutting the wires, soldering them, and then desoldering and re-soldering if I decide I don't like the e-manage or I decide to move onto something else. Any input is appreciated.
-Travis
U12 DET / JWT brain / Greddy E-manage+support tool+laptop / HKS Type-0 turbo timer / Greddy Type-S BOV / Magnaflow 2 3/4" exhaust / Starion FMIC w/modified endtanks / Clutchnet lightweight FW-Fiber-fiber clutch-PP (oh so choice)
Clarion HU / Clarion Changer / Cadence A7hc / Audiobahn A6600E / Audiobahn ABC600 / Alpine Type-R 12's / PG RCA's / Stinger Power Wire
N13 Freak is offline   Reply With Quote
Old 06-24-2004, 06:47 PM   #2 (permalink)
I like food
Re: ECU wiring question (piggyback ecu related)
wow. high quality ones? i just used the home dept crap. 2 bux for 8 connectors. it works fine. we installed in my buddy's 240. but had to take it out, and it's not causing problems.
PoorLiLPoop is offline   Reply With Quote
Old 06-25-2004, 01:21 PM   #3 (permalink)
Audio Nut
lol, anyone else have any thoughts?
Old 07-06-2004, 09:55 AM   #4 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
There are only two wires on the main harness that require a cut and solder. The rest are simple taps for the emanage to pull information. For the taps use some nice vampire connects (they clamp on the wire and have a female spade on the other end for a male spade to slide into). For the splices, you have to solder to get the absolute best connection as any resistance can mess up the signals to and from the emanage.
Brent
coach is online now   Reply With Quote
Old 07-27-2004, 09:33 AM   #5 (permalink)
If money isnt a problem and you want a good connection use "Hypertac" connectors, low insertion force, low resistance, high vibration resistance. use google to track down a local supplier cos I think RS components is a bit far from you.
Mike
UK-SRi is offline   Reply With Quote
