Old 07-09-2004, 07:24 AM   #1 (permalink)
I lika da turns
Stereo install
I just bought a Pioneer headunit from here on the forums. I got it the other day and was looking how to install it but it has some kind of metal slider around the headunit. What is this metal slider for and do I need it? Is this where the factory radio brackets mount on to? Anyone else have problems with getting the screws out of the stock radio brackets (the ones that mount to the radio itself)? Thanks.
Ben
'05 Subaru WRX STi
'93 SE-R Rocketsled (SOLD)
Drive it like you stole it (or at least try to before it breaks)
http://www.imagestation.com/picture/...1/fa5710dd.jpg
Cannibal is offline   Reply With Quote
Old 07-09-2004, 08:58 AM   #2 (permalink)
Moms love me
Re: Stereo install
Pull the metal slider off the headunit, dont need it in our cars. Remove the screws holding the brackets to the old headunit, and mount them the exact same way to the new headunit.
94 Firebird Formula A4 3.42 [13.6@102]
[Boltons]
Bryan Smith is offline   Reply With Quote
Old 07-15-2004, 12:32 PM   #3 (permalink)
penetration specialist
Re: Stereo install
Some people should not do car audio...............
classico 92
flsoundfx is offline   Reply With Quote
Old 07-19-2004, 02:27 AM   #4 (permalink)
I got turbo envy
Re: Stereo install
The metal sleeve around your new headunit is what prevents it from sliding out of the hole every time you step on the gas. put it in the factory hole where the head units goin, bend down the little tabs to keep it in place, and then the new head unit should slide into it and click into place. unless i'm thinkin about the wrong thing here....
91 nx2k - JDM sr20de, fstb, custom short shifter, intake, 2 1/2" catback exhaust, SAFC, autometer cf gauges, custom dash gauges, m3 mirrors, 17" rims, KYB AGX/GC setup
4 Sale: stock fog lights, gr2 struts, stock springs and struts, USDM sr20de parts, much more..
I might have high ambitions but my dream is clear and it is slowly being realized...
klorti is offline   Reply With Quote
Old 07-19-2004, 04:18 AM   #5 (permalink)
Moms love me
Re: Stereo install
Yup no need for the metal sleeve, B13's (and I found out today S13s) do not need the sleeves, the OEM mounting brackets mount directly to aftermarket headunits. The sleeve is needed only if you use a "Install" or "Dash" kit. To make an aftermarket headunit properly fit into an oversized (mostly domestic ive found) stereo spot.
Old 07-19-2004, 09:08 AM   #6 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
Re: Stereo install
You ARE thinking of the wrong thing, and you prolly confused the poor guy!
Just use the metal brackets off your old radio like the other guys said. Then screw that in, pretty simple.
Brent
Old 07-19-2004, 10:51 AM   #7 (permalink)
Moms love me
Re: Stereo install
Brent
Old radio? :-P
Old 07-19-2004, 11:31 AM   #8 (permalink)
I lika da turns
Re: Stereo install
I had to get new brackets and screws (which do not fit in Pioneer headunits by the way) from Nissan but I finally got it to work. Now I think one of the wires which I didn't solder together has shorted out my dash and running lights. Did a search on this and it seems one of the orange lights that I left unhooked could be the problem.
What color wires should be left without a connection on the back of the radio? I think I have a black (don't need because using the brackets as ground) and two orange (can't remember what those are for). I soldered the two blue ones coming off the headunit into one and then attached that to the blue one coming off the Best Buy factory harness adaptor. Should I have done this with the blue wires? The radio works fine but I think I just need to tape the unhooked wires so they stop shorting stuff out.
Old 07-19-2004, 11:34 AM   #9 (permalink)
Moms love me
Re: Stereo install
If you have the factory harness adapter you shouldn't worry about what wires should be connected. The adapter connects all the important ones for you.
Old 07-19-2004, 04:40 PM   #10 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Re: Stereo install
It sounds like your radio doesn't have wires for the dimmer, but the aftermarket harness does. Tape those wires off, or use some heat shrink to keep them from shorting out.
1991 Sentra SE-R
The community is here.
Old 07-20-2004, 07:20 AM   #11 (permalink)
I lika da turns
Re: Stereo install
I think the illumination wires must have shorted out to the frame. I shouldn't have been so lazy and taped the wires.
I looked yesterday and pretty much the black, orange, and blue wires are not doing anything.
Thanks for all your help! I hate being a noob but stereo is one area I have no idea about.
Old 11-08-2005, 12:24 AM   #12 (permalink)
newbie
Pretty White's Avatar
Old thread, but I just bought a Pioneer radio and the solid blue and orange wires off the harness kit does nothing, but the black is a chassis ground. Am I correct? The orange says "Illumination" and the Blue is what? The install instructions do not mention them on the Pioneer harness.
Originally Posted by sonny
Old 11-09-2005, 01:02 AM   #13 (permalink)
Slap a volt meter on it. When the stereo powers up, you will more than likely get 12V on that blue wire. It's a remote on for an amp.
Good luck!
My NX 2000
joeangel is offline   Reply With Quote
Old 12-20-2005, 11:48 AM   #14 (permalink)
usually, there are two blue wires - one solid and one with a white stripe. The one with the white stripe is for a power antenna and only gives +12V when the tuner is selected, and the other is for the amp turn-on and gives +12V as soon as the headunit powers up.
FlippyBoy is offline   Reply With Quote
Old 01-22-2007, 06:23 PM   #15 (permalink)
Se-R and 510 owner
Ok old thread. i waired in my knewood to my se-r 96. wired everything in the way it was with the previous stero. turn the key to on....nothing. so i un did everything and re hooked up the old stero, turned the key to on....nothing.. any ideas to what i might have fu*ked up..?
danfiveten is offline   Reply With Quote
Old 01-22-2007, 07:31 PM   #16 (permalink)
did you check the fuses? if you have a voltmeter, make sure the power wire is getting +12V.
Old 01-22-2007, 08:37 PM   #17 (permalink)
Se-R and 510 owner
weird thing is the fuse is fine. and even when i put back in the old stero it still wouldnt work.... my \volt tester is broken so i need a new one to try it...but i dont understand why all of a sudden the power wire would go out.
Old 01-24-2007, 07:30 PM   #18 (permalink)
Se-R and 510 owner
So i tested. theres power geting to the deck, the ground is fine. i was bout to give up and moved the deck and it turend on for a secound. so i rechecked the connections but nothing..?....im wondering if it has something to do with the wiring harness in the car.. its werid for it to stop working all of a sudden though.
Old 01-02-2008, 09:39 PM   #19 (permalink)
Darth Egg
----Is this the adaptor that allows you to hook up an aftermarket head unit to the factory plugs, So i dont have to cut and splice? If so where can I get one? Price?
--Sorry about raising this from the dead, but it seemed closest to what I was looking for.
New!! (to me) 1993 Nissan NX2000-intake,exhaust,strutbar,blah,blah,blah
2004 Oregon Region SCCA Solo2 STS Champ, 2006 EESCC STS champ
2005 SRT-4 ACR (autocross car)
-F1 and ChampCar nutcase.-
MySpace- http://www.myspace.com/vvt4me
PMKN_PI is offline   Reply With Quote
Old 01-09-2008, 09:09 AM   #20 (permalink)
eric96ser's Avatar
Any shop that does car audio installs will have one. Last time I got one, it was ~$20.
