Re: wiring adjustable thermostat and fan
OK man, you need to get a standard 12V/30amp automotive relay from radioshack or somewhere like that. Then, just wire the "ON" wire of your ignition to the relay pin on the relay. Then wire in the 12V and ground to the relay. The 4th wire will go to your fan power wire. Then ground the other wire on the fan to a GOOD chassis ground.
Brent
