Old 08-02-2004, 02:27 PM   #1 (permalink)
purist
Trying to kill a horse
Grounding the Amps
Where are you guys grounding your amplifiers?
If you have an amp under the front driver's seat where would be the best location for it to be grounded to?
purist is offline   Reply With Quote
Old 08-02-2004, 02:40 PM   #2 (permalink)
Sr20kidD
Yes Dear.
Re: Grounding the Amps
I grounded mine to the metal bracket that holds the seat rail down. On the side there should be the seat rail platic cover, remove those and walla grounding point. Just make sure to clean it with a wire brush first.
Sr20kidD is offline   Reply With Quote
Old 08-02-2004, 03:25 PM   #3 (permalink)
byronchrisp05
its stock ;)
Trader Rating: 46 (100%)
I grounded mine to the bolt that holds the seat belt on.
race car:
1997 200sx se-r - t28 in the works
winter beater:
1995 200sx se-r- crashed then sold
1990 Subaru Legacy- you know you want one
byronchrisp05 is offline   Reply With Quote
Old 08-02-2004, 03:49 PM   #4 (permalink)
shelmoneySER
backyard mechanic
Yea take up the seats, Look for a bolt under there
shelmoneySER is offline   Reply With Quote
Old 08-02-2004, 05:57 PM   #5 (permalink)
Tre`
You got SERVE'd
My amp is closer to my trunk. I just pulled up the back seats (real easy) and there are plenty of awesome spots under there.
1998 200sx SE-R SR20VE
JWT ECU, HS CAI, JWT pressure plate b15 clutch disk, Phantom Grip LSD, Dual MSD RPM module and selector, ES motor mount insterts & bushings
Tre` is offline   Reply With Quote
Old 08-02-2004, 07:02 PM   #6 (permalink)
purist
So I have a faint high pitched squeel. Sometimes it's really bad, but morst of the time I can't here it. I have my suspicians as to what it is, but I'd like to hear your opinions on it.
I gounded mine to the bolt that is under the plastic cover nearest the center of the car, fyi.
Old 08-13-2004, 11:44 AM   #7 (permalink)
flsoundfx
penetration specialist
Always mount a ground to a point that is to the frame or body itself. Never mount to a bracket that is in turn mounted to the ground. I use the Bolt that holds the seat down. It is a Big chunk of metal because of how much pressure it has to hold to be safe in holding a seat in.
classico 92
flsoundfx is offline   Reply With Quote
