Old 08-23-2004, 07:31 PM   #1 (permalink)
rf_fanatic
Need help wiring CD player
I just bought my 91 SER and all the wires for the headunit are dead. I tested them with a multimeter and got 0 volts . Looks like I have to rewire it myself. I know that I need a power constant from the battery and that I need to run new speaker wire to the speakers and run a ground. Which wire should I use for the ignition? Is there anything else I need to do to get my CD player running? Thanks for the help
rf_fanatic is offline   Reply With Quote
Old 08-23-2004, 07:44 PM   #2 (permalink)
Sanyo
MMM, organized crime
Re: Need help wiring CD player
CD players are easy as hell to wire. Run a constant 12v, a ground, and then tap into a accessory 12v somewhere else..like on the cig lighter. Maybe just use a relay so it doesn't try and pull to much power from the cig lighter. If ALL the wires are dead, maybe try and trace down the problem? New speaker wires..those are simple enough. Remote wire if you got a sub and that may be it. Some cars have auto-antennas, we don't though so it's no worry. Hope that helped, dunno!
When I heated my home with oil, I used an average of 800 gallons a year. I have found that I can keep comfortably warm for an entire winter with slightly over half that quantity of beer.
Sanyo is offline   Reply With Quote
Old 08-23-2004, 07:50 PM   #3 (permalink)
rf_fanatic
OK Ill run the accessory off the cig lighter that sonds easy enough. Do you know which wire on the cig lighter i need?
Old 08-23-2004, 08:06 PM   #4 (permalink)
martin_g34
70/30 Racing
martin_g34's Avatar
Trader Rating: 20 (100%)
There should only be two. Lick your fingers and when you feel a tickle that's the one you want!
99 SE-L boost coming soon
92/93 SE-R daily pimpage
92 G20 - PTD #73
martin_g34 is offline   Reply With Quote
Old 08-26-2004, 12:09 PM   #5 (permalink)
rf_fanatic
How does the relay work? Do i run 2 power wires from the battery and then tap off the cig lighter for the realy turn on? Also where is a good spot to groud? Sorry for all the stupid questions, Im a sentra newb, but old school in altimas.
