Old 08-26-2004, 08:07 PM   #1 (permalink)
Battery Trouble
I am having some problems with getting continuous juice off my battery. Last fall I took off the stock negative clamp becuase It was rusted to h*ll and replaced it with a brass universal part. I soldered the 0 guage cable to the stock wire I cut. All was good except I also cleaned the terminal with a brush. I had to crank down the clamp to get it tight (almost solid).
Recently I had to take it off for some other work and now it seems to be coming loose. Is there a conductive sleeve I can fit over the terminal so I don't have to tighten the clamp so much? Any other suggestions?
'97 SE-R ... Custom Dynomax Exhaust ... Headers ... KYB/AGX Suspension ... Slotted Front Rotors ... SS Lines
I've got a fever, and the only prescription is more cowbell.
kegger0001 is offline   Reply With Quote
Old 08-29-2004, 04:28 PM   #2 (permalink)
not my president
Re: Battery Trouble
get a new wire and battery terminals
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 08-30-2004, 03:33 AM   #3 (permalink)
GT2835R
Re: Battery Trouble
Yea, just buy some better terminals.
Rey Uy
99 SE-Limited
Old 08-30-2004, 05:06 PM   #4 (permalink)
Red line chaser
Re: Battery Trouble
/\ /\ /\ Basically. /\ /\ /\
Universal battery terminals are usually a single generic size that fits most positive and negative terminals. It usually has to be cranked really well to fit onto the smaller negative terminal that we use. Picking up a proper sized negative terminal and upgrading the ground wire will help you out a lot.
96 SE-R: SR20VE - bolt-ons
97 SE-R: GtiR - getting there - need $$$
03 Altima SE V6: alarm+remote start/Pioneer TV+DVD/MB Quart comps/US Amps TU-4360/Stinger blocks, Expert RCA's, and 0 gauge wiring/rest of system going in shortly
WickedSR20 is offline   Reply With Quote
Old 08-30-2004, 07:37 PM   #5 (permalink)
Re: Battery Trouble
Thanks for the info. Has anyone ever dealt eith the types with the quick release nob? It seems like it would be pretty handy when doing work regularly. Especially for like 6 bucks on ebay.
