Originally Posted by GRMPer
Where do you B13 SE-R racers measure your ride height? the horizontal rocker panel area near the jack point or the vertical "crimp" at the lowest point?
I used the latter, getting about 5.75 and 6.25 at the lowest point on the crimped vertical at the jack point.
Too low? Just right?
http://www.grassrootsmotorsports.com/ser.html
Thanks!
Per
About right, don't go any lower, the geometry sucks on these cars and going lower just makes a mess and pops axles. Uusaly I measure from the fender lip to the center of the hub. Then I measure from the bottom of the sptring perch to the end of the collar on the strut. This way if I take things apart, I don't mess up my corner weighting.
When you corner weight make sure you disconnect your swaybars and after adjust the preload out of them. Its easy with the progress bars.
