Go Back   SR20 Forum > Motorsports > Autocross & Rally Racing
Old 03-04-2006, 01:42 PM   #1 (permalink)
mpg9999
B13 Rear Camber Adjustment
This is done by adjusting the length of both of the parallel (radius) arms, correct? Ingalls actually sells an arm:
I'm guessing that you use the toe adjustment to adjust the length of the other stock arm?
The other option is to make your own, like Greg Amy did:
I'm guessing with both arms you would get more adjustability and stronger arms? Greg also used heim joints there, while the ingalls uses either rubber or polyurethan. How would the NVH be using the Heim joints? Also, I have read that the trailing arm is really not needed to locate the knuckle. Its there just to add strength. So, with stronger tubular arms, would it be possible to completely ditch the trailing arm since it binds?
Another advantage to this that steve f pointed out to me is that you could take away negative camber by relocating the holes on the strut ears to give you more strut to wheel clearance, then get the negative camber back by adjusting the parallel arms.
I was also wondering how changing the length of the parallel arms changes other aspects of the suspension geometry, like roll center, scrub, etc.
Old 03-04-2006, 01:46 PM   #2 (permalink)
wacked2882
Got the shakey hands
pushing the lower links out farther will give you a wider track. You don't want a wider track on the rear of a fwd car.
Nick Jackson
www.racepa.com
wacked2882 is offline   Reply With Quote
Old 03-04-2006, 02:07 PM   #3 (permalink)
Avshi750
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
i just my first pair, two on backorder.
you got it right, the adjustment of the arms allows fine tuning of alignment.
two is better than one, despite what their site says... the instructions in the box say not to use on race cars?!?
Avshi750 is offline   Reply With Quote
Old 03-04-2006, 10:23 PM   #4 (permalink)
Greg Amy
NX2000 Racer
Greg Amy's Avatar
Just to clarify: those arms are on Norm Nelsons' Classifc, currently built to Production specs. The car was an ex-World Challenge car, built by the Archer Bros team, IIRC. Such arms are not legal in Improved Touring.
If you did not install two arms, any adjustment would result in toe changes. Also, this suspension is not adequately located without the forward link; any fore/aft forces would simply collapse the rectangle...
Kakashi Racing T-Shirts Now Available!
http://www.kakashiracing.com/tshirts.html
2006 ARRC/NARRC/NERCC ITA Champions!
My lug nuts have more torque than your Honda engine!
Greg Amy is offline   Reply With Quote
Old 03-04-2006, 10:45 PM   #5 (permalink)
98sr20ve
I can't imagine the b13 suspension working with out the trailing arms. It would move forward or back at any time. The binding you are referring to would be eliminated to a great degree by that double heim joint arm setup. The arc of those two arms is up and down. The trailing arm moves in a arc. This pulls the arms forward and back as it moves. The ES bushings in particular resist this forward and back movement. Those Heim joints would allow it to move freely forward and back so binding would be eliminated.
On my S13 Heim joints have not hurt the ride. They actually helped the ride greatly when paired with ES bushings as they elimated the binding in my multilink rear suspension as well.
To get some extra clearance in the rear at the hub and then getting the camber back at the arms would not change the track too much. It just depends on how much you try to adjust the top.
That arm should be legal in a lot of classes as it does not use metalic bushings.
Steve
06 G35 6MT
Old 03-04-2006, 11:47 PM   #6 (permalink)
Sr20kidD
Yes Dear.
who makes these,, or which website
Sr20kidD is offline   Reply With Quote
Old 03-05-2006, 01:39 AM   #7 (permalink)
mpg9999
In my first post .
Old 03-05-2006, 02:22 AM   #8 (permalink)
Avshi750
Avshi750's Avatar
$90 a pair, but they are on back order last i heard. I'm waiting on two.
a friend just ordered from Summit, similar price and back ordered too.
http://www.ultrarev.com/ecart/shopdi...r a&Year=1993
Old 03-26-2006, 09:56 AM   #9 (permalink)
SENTRASER
Drive it like ya stole it
SENTRASER's Avatar
Trader Rating: 33 (100%)
Camber adjustment 'ey? Quite a concept.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by chriscar
