Go Back   SR20 Forum > Motorsports > Autocross & Rally Racing
Old 08-02-2006, 10:40 AM   #1 (permalink)
UK N15 Almera Enthusiast
ABS when racing?........
Do you guys race using ABS or do you dissable/remove it?.....I do a fair amount of track days and when i does kick in it feels kinda strange.
Any advantages or disadvantages for not using it?......
Thanks in advance.
158.1 WHP and 141.9 Lbs 1/4 mile 14.42 @ 95mph 2381 lbs with driver
http://www.sr20forum.com/gallery/***...ry.php?cat=762
rowdy-GTi is offline   Reply With Quote
Old 08-02-2006, 11:58 AM   #2 (permalink)
NX2000 Racer
Greg Amy's Avatar
SCCA Improved Touring requires it be disabled...
Kakashi Racing T-Shirts Now Available!
http://www.kakashiracing.com/tshirts.html
2006 ARRC/NARRC/NERCC ITA Champions!
My lug nuts have more torque than your Honda engine!
Greg Amy is offline   Reply With Quote
Old 08-02-2006, 12:23 PM   #3 (permalink)
Leggo of my eggo.....
Thanks in advance.
Most track guys disable it. The disadvantages of running ABS occur when you have an off. You've heard the expression "two feet in". Well, with ABS that whole concept gets screwed up. The tires don't lock and your out of control spin/crash gets unpredictable for the other cars behind you. The other disadvantage is when you're off in the mud/gravel trying to get it whoa'd up. With ABS, again the wheels don't lock which means you'll fly over the surface instead of digging in. I've seen lots of DE guys go into the barriers instead of stopping in the gravel because of this.
Hammerin Hank is offline   Reply With Quote
Old 08-02-2006, 12:34 PM   #4 (permalink)
That makes alot of sence. Thanks Hank.
Old 08-02-2006, 12:37 PM   #5 (permalink)
employed again
I think our ABS systems suck-ass. Everyone who has it should pull their ABS fuse. Especially for auto-x and track work. JMO of course.
Matt
MaddMatt is offline   Reply With Quote
Old 08-02-2006, 12:38 PM   #6 (permalink)
so sin se-r
i agree with everything said above...but i want to add something. no human can modulate a brake pedal with the same speed and efficency as an abs comp. so your stopping distances (normal braking line) may become longer than usual.
Peter Janick
New Ride:
1997 Silver b14 SE-R
Tein Basics
CAI
91 intake cam
Short Shifter
H/S gen 4ish
side piped
ngk irrid
a/c delete
Falken Hanabi wheels (11 lbs.!!)
205/50-15 BFG G Force Sport
MIXMASTAP2 is offline   Reply With Quote
Old 08-02-2006, 12:41 PM   #7 (permalink)
merely a flesh wound
chriscar's Avatar
You haven't driven a B13 with ABS then.
Not only is it painfully slow, but it's just 2 channel instead of 4, so when your right front tire for example starts to slip, it cuts brake pressure to it, as well as the left rear.
The only good thing about B13 ABS is that it's easy to disable.
Old 08-02-2006, 12:43 PM   #8 (permalink)
better in the wet maybe?.....I`m from the UK remember!
Old 08-02-2006, 12:54 PM   #9 (permalink)
chriscar's Avatar
Well, you tell me. Have you driven this ABS equipped car?
You're not going to get anything positive about the ABS in a B13 from me. I had a 92 B13 with it years ago, and disabled it after experiencing how bad it was in the dry, in the wet and in the snow.
One thing to check though, I was going through this same conversation with another fellow on the forum a few months back. I think he was from the UK, and IIRC, they got a different system than the US, perhaps a 4 channel one.
Old 08-02-2006, 01:04 PM   #10 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
LOL, yeah our ABS system is quite innefective really. To slow to really react properly. I disabled it on the street and for SURE would have it disabled on the track.
Brent
Old 08-02-2006, 01:06 PM   #11 (permalink)
Yes for the past 4.5 yrs! It is 4 channel. It rarely comes on but when it does, like i say it`s a kinda funny sensation.
Old 08-02-2006, 01:07 PM   #12 (permalink)
chriscar's Avatar
In that case, I reserve all comments. Your system is different.
Old 08-02-2006, 01:17 PM   #13 (permalink)
employed again
I am absolutely positive I can outperform the ABS system on U.S. B13s. No problem at all. In all honesty, I think locked up squeeling tires stop more effectively than our ABS system.
Old 08-02-2006, 03:48 PM   #14 (permalink)
A.K.A. 2Fass240us
All the kids remove it completely. I saved 15.8 pounds on the actuator and 3.2 on the bracket. The fasteners, computer, wire, and sensors are probably just North of 1 pound. I did not, however, weigh all the different brake lines from switching over to a non-ABS BMC and lines. Maybe another pound here to be conservative?
Based on Matt's comments, that's 21-23 pounds of pure crap that's easy to ditch. And cheap too! Bringbring!
-Andy
240SR track donkey
Old 08-02-2006, 04:17 PM   #15 (permalink)
pwnd
Bowlcut's Avatar
how hard was it to remove the abs totaly? you did replace the MC right? and all the lines? or where does the lines change? i want to remove it totaly from the NX. makes changing oil a real pain
-Kevin
We are a community
Old 08-02-2006, 04:21 PM   #16 (permalink)
chriscar's Avatar
The "ABS Elimination Bible" as told by Chriscar
http://www.sr20forum.com/technical-information-library/157899-b13-non-abs-conversion.html
Old 08-02-2006, 05:34 PM   #17 (permalink)
SHIFT_e
pyrocrickett's Avatar
Is there a simple way to know/check if my B13 has ABS? I've always assumed it didn't, but I've never really tried to figure it out for sure. Is just the fact that I don't think I do evidence enough that I don't?
Proud GA16DE Driver No More
Now I'm driving something a little different...
It's more fun to drive a slow car fast than a fast car slow.
pyrocrickett is offline   Reply With Quote
Old 08-02-2006, 06:19 PM   #18 (permalink)
employed again
There's a really big indicator light right in the middle of the instrument cluster that says "ANTILOCK".
My guess is you don't have ABS. Because it's such a horrible system you absolutely would not forget what it feels like when it engages.
Old 08-02-2006, 06:37 PM   #19 (permalink)
SHIFT_e
LOL... guess I was right then!
Old 08-02-2006, 08:41 PM   #20 (permalink)
El Rey de los Chingones
Isfahan's Avatar
After reading the seething hatred for the ABS system on the B13's, I'm almost afraid to ask this, but has anybody ever tried retrofitting a functional 4-channel ABS system into a B13? I hate my ABS system on my B13 6 months out of the year, but I will say that with my high performance all-season tires, it has saved my ass a couple of times in the snow piles I have to deal with in MI.
WE are a community
Isfahan is offline   Reply With Quote
