Go Back   SR20 Forum > Motorsports > Autocross & Rally Racing
Old 09-09-2006, 11:37 AM   #1 (permalink)
Honda 2.0L question
How many variations of the Honda 2.0L K series engines are there? And at what HP?
We have a Ex-Honda Michelin Civic in our class with a K20 swap (or so I'm told) and we don't seem to have any problem out pacing him in our stock SR20 powered B14 SE-R. On the back straight at Mosport he is generally able to keep up, but certainly not out power us, the car is a base 2004/5 Honda Civic DX.
01 Sentra SE/PP
K&N filter,Yokohama ES100's (street), Toyo RA-1 on Team Dynamic 15" for track, Brullen exhaust, Koni's, Eibach Pro-Kits, Stillen header, Nismo rear anti-roll bar
'95 SE-R #200 Castrol CTCC Touring.
Silver SE is offline   Reply With Quote
Old 09-09-2006, 11:42 AM   #2 (permalink)
Professor Dingbat
This is the 'Bearss/Young' car?
The K20 engines that came in older civics ('early 2000's) came with 160hp. I don't remember all the details but it is not real VTEC. I beleive it opens only one intake valve at low RPM for better swirl, then switches to opening all 4 valves at higher RPM, but there are no multiple camshaft profiles.
How is your car coming along?
Old 09-09-2006, 12:31 PM   #3 (permalink)
We'll know soon. It was pretty bent but looks like it may be ready for the enduro.
Old 09-09-2006, 12:45 PM   #4 (permalink)
its stock ;)
Trader Rating: 52 (100%)
www.honda-tech.com
race car:
1997 200sx se-r - t28 in the works
winter beater:
1995 200sx se-r- crashed then sold
1990 Subaru Legacy- you know you want one
byronchrisp05 is online now   Reply With Quote
Old 09-09-2006, 12:49 PM   #5 (permalink)
Luke Pighetti
Taiden's Avatar
http://hondaswap.com/reference-mater...ne-list-29128/
enjoy for all you clueless honda hating nissan guys.
Old 09-09-2006, 02:31 PM   #6 (permalink)
there are 3 types of VTEC, one help emmissions with the closing of one valve for a better swirl in the chamber, one boosts power by switching the lobes on the cam, and IIRC the 3rd uses both.
-Jon
Daily driver: 98 Maxima SE ... Koni, Ground Control, Stillen, Enkei, Falken, Warpspeed, 14.9@95.
06 Drag car: 91 Sentra SE-R ...Lowport, U12 turbo kit, gutted, on a budget, 247whp@10psi, 13.1@110. TOTALLED.
08 Drag car: 94 Sentra E ... Built lowport, T3/T04E, gutted, still in the making.
JSutter is offline   Reply With Quote
Old 09-09-2006, 05:13 PM   #7 (permalink)
Professor Dingbat
The third kind is i-VTEC. It is similar to BMWs Vanos, or Toyota's VVT-i in that it changes the camshaft timing relative to the crank on the fly.
Old 09-10-2006, 07:38 AM   #8 (permalink)
Luke Pighetti
Taiden's Avatar
there are actually four, the three listed above and i-VTEC that works exactly as FastNX stated.
Old 09-10-2006, 04:06 PM   #9 (permalink)
You need to be corrected. You got the idea, but not quiet. The K series can range in tsx, rsx, civic, and Fit(?). The rsx engine has 200hp, jdm type r rsx has 220hp.
How v-tec works: the first stage, which is usually under 5-6K depending on engine, uses 2 of the 3 lobes. Those 2 lobes open 2 of the intake and 2 of the exh valves at a low lift and duration. The 2 intake lobes are made with slightly different to help the tumble effect.
When high rpm is reached the big lift and duration lobe kicks in. All valves are always opening and closing.
i v-tec is the same thing, BUT they also add varable valve timing for the intake cam. TIming can be changed while the vehicle is in operation to open intake cam sooner or later, which can also effect duration.
So its basically variable lift like hondas first v-tec or nissans VVL, but also has variable timing, which almost everyone has now. Toyota vvti, nissan VTC, BMW Vanos, etc etc
"A couple of Nissan Sr20's will pull a premium one week before race wars." (Johnny Tran, fast and furious) LOL
420sxDET is offline   Reply With Quote
Old 09-11-2006, 11:43 AM   #10 (permalink)
so sin se-r
the k20 out of 2000 honda civic si is only 160chp. the new "base" k20 is 197chp. both have ivtec
Peter Janick
New Ride:
1997 Silver b14 SE-R
Tein Basics
CAI
91 intake cam
Short Shifter
H/S gen 4ish
side piped
ngk irrid
a/c delete
Falken Hanabi wheels (11 lbs.!!)
205/50-15 BFG G Force Sport
MIXMASTAP2 is offline   Reply With Quote
Old 09-11-2006, 12:49 PM   #11 (permalink)
Luke Pighetti
Taiden's Avatar
The Fit does NOT, I repeat does NOT have the K20A. If it did, everyone would know about it. 250 whp NA Fits, that's the end of everything for everybody.
Old 09-11-2006, 04:53 PM   #12 (permalink)
I meant K series. That is also why I had a question mark behind it. I was not sure if the 1.6L engine it uses is a K series. The tsx uses a 2.3 or 2.4? I forgot. If they are K series, they would b similar, except certain details
Old 09-11-2006, 10:51 PM   #13 (permalink)
Luke Pighetti
Taiden's Avatar
I am 99% sure that a 1.6L SOHC motor with VTEC making 128 hp is a lot more like a d16z6 (EG hatch si, all EX coupes and sedans until recently).
Old 09-11-2006, 11:17 PM   #14 (permalink)
I saw this show called Super Tuner Challenge, and the fit engine looked likea DOHC v-tec, but small displacemet. I guess they were doing a swap or something. I guess it does come with a SOHC v-tec.
