Go Back   SR20 Forum > Motorsports > Autocross & Rally Racing
Old 11-20-2003, 10:38 AM   #1 (permalink)
nx avenir at road atlanta?
Hey, I have spent some time on a road course, mostly summit point, first with an nx with bolt ons (early 90s), then a turbo miata I built in the late 90s. The miata was a pretty well built car (flyin miata kit), including a fat alluminum radiator, and yet it still would get hot. The LINK computer system had a "limp mode" mechanism when it got too hot on the track, but it was still frustrating to be whipping up on a bunch of "faster" cars only to head down a straight and have it slip into limp mode and have everybody want to get back in front of me. So, my question is. I just bought an nx with an avenir in it. It is a well built car, but the radiator hasn't been replaced. I now live near road atlanta, and I want to spend time on the track. Is it possible on a stock radiator? What about on an upgraded radiator? Is there a bolt in radiator for the job? Thanks in advance. Danny
dwike is offline   Reply With Quote
Old 11-20-2003, 11:36 AM   #2 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
there are a few radiators you can drop in that will do MUCH better than stock, though the stock NX radiator is a pretty good one. There is a Modine unit and a couple KOYO units. Koyo makes the huge all aluminum race radiator and a more replacement sized radiator. Modine makes a radiator that is copper/brass and is thicker than the NX radiator. It is like $160, where the Koyo will be a lot more (like $350). Here is a page with Koy0 and CSF radiators http://www.absoluteradiator.com/Prod....asp?idProd=27 the modine is like the bottom one on that page, just a tad thicker. Modine can be bought from Carlos Faxas through the forums here. I think his name is 93 blackbird.
Brent
coach is online now   Reply With Quote
Old 11-20-2003, 02:02 PM   #3 (permalink)
Copper Brass is not as good as aluminum. The Koyo I bought had inlet and outlet ends that were smaller then the oem ones (by about 1/2). I returned it (came damaged anyway). Cutting holes in the bumper cover and using some ducing to insure the air getting in does not bypass the radiator will do a lot to help with cooling. More then a brass radiator would be my guess.
Steve
06 G35 6MT
Old 11-20-2003, 06:32 PM   #4 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
Danny-
There will be a new-to-the-market 3 core aluminum radiator available for your NX very shortly. It will be much thicker than stock, and you'll probably want some slim fans since you have a turbo sitting down low.
If your intercooler is front mounted, it will really block the airflow to the radiator, especially on a NX. My SE-R heated up every 3 laps in Birmingham last month, requiring a cooldown lap.
I am prototyping the B13 SE-R version of this radiator, and it is being shipped to me today.
Sit tight for a month or so, and you'll be hearing a lot about it. Price will be in the $300 range.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
Old 11-21-2003, 02:17 AM   #5 (permalink)
Corporate Bullsh*t
I had no cooling issues at Birmingham with a NISMO (GTi-R) radiator, PTI cooling fans, and water wetter. It never went above 205*F even though I was running a lean fuel mixture.
However, the new "prototype" radiator should be promising!
92 SE-R, turbo
blackb13 is offline   Reply With Quote
Old 11-21-2003, 08:28 AM   #6 (permalink)
It should fit the b13-b14 then.
Three row, Aluminum, $300
Do not underestimate the benifits of ducting. It is known that ducting can improve cooling on a radiator by up to 30%. The GTIR radiator is not a 30% improvement. In other words. Do the ducting first. It's a lot cheaper. I am convinced that it was worth at least a 20% improvement on my car.
Old 12-02-2003, 01:16 PM   #7 (permalink)
Drinking The H Juice Now
BigB's Avatar
don't forget water pump issues on a b-13... especially at RA...
1992 SE-R WHT - SOLD
1992 SE-R BLK - R.I.P.
2001 -Mazda MP3 #60 of 1500
1991 Integra LS -
BigB is offline   Reply With Quote
Old 12-02-2003, 11:55 PM   #8 (permalink)
Enjoy the GTR Matt!
Trader Rating: 23 (100%)
Couldn't he do an electric water pump? (if this isn't a daily driver) That should cool it pretty good as well.
Ducting is cheap too, between that and the electric pump, I'd think it would be OK.
I'd like to see that NX though, I'm looking at trying to put the same thing in one of my NXs
Old 12-03-2003, 11:03 AM   #9 (permalink)
Veritas
Let me clear one thing up: To me, 208* is 'hot' and headed for meltdown quickly, at least on my car. I know I can get away with higher temps, but do not wish to go there due to my engine's high mileage. In the third session at Birmingham, I hit 208* after about 4 laps, and decided that was time to cool down.
So, it's not as hot as some would think. But still...heading there quickly.
The new prototype *should* be in my hands shortly. It has been delayed due to an unforeseen accident at the radiator shop that is producing them. I'll have full pics of the install when it does arrive.
Old 12-03-2003, 12:50 PM   #10 (permalink)
Honda Employee...
what about intercooler or radiator sprayers?
-Zack
-'91 SE-R, Aztec Red: JWT Pop-Charger, Fidanza Flywheel, JWT PP w/01 SE disc. AGXs w/GC coilovers (300/279) & C/C plates. NX2K Brakes w/Carbotech pads & Crown SS lines. Progress rear sway bar. Active Tuning RSTB, ES Bushings & motor mounts.
gottabfast is offline   Reply With Quote
Old 12-03-2003, 04:24 PM   #11 (permalink)
Traitor in your midst
I can attest to the Mezier electric water pump kit. I got it from Summit for my SE-R Cup NX and it has been a great combo with just the stock NX radiator. To me 208 isn't dangerous hot, but it is getting there. On hot days we'll see up to 220, but I wouldn't want to go higher than that. It also depends on where you measure the temp.
-Jim
SE-R Cup Hooligan
Jim #98NX is offline   Reply With Quote
Old 12-06-2003, 08:08 PM   #12 (permalink)
I'm in the market for a new radiator. Lets us know when you get your hands on it.
Old 12-06-2003, 09:12 PM   #13 (permalink)
Corporate Bullsh*t
First of all, I said 205 not 208. Second of all, the stock fans turn on around 200*F. I was told not to worry until 225*+. I don't think those temps are high...especially for a car that was in boost for 8/10th's of the course.
Greg, your not getting old on me are you???
Old 12-06-2003, 09:53 PM   #14 (permalink)
Veritas
Yes, I am getting old. <sigh>
Prototype radiator was fitted today on my car, and we need to make a few minor tweaks before it will fit like a glove in a B13.
So, 2 more weeks to make corrections and I should have detailed install photos and writeup here on the forum.
P.S.-- The new radiator is a two core unit, not three as previously mentioned. It is more than twice the thickness of a stock B13 unit, however.
Old 12-18-2003, 10:24 AM   #15 (permalink)
I am assuming this 2-core unite will still be superior to the 2-core in an nx, no?
out there somewhere
Old 12-21-2003, 09:44 AM   #16 (permalink)
For what it is worth I was told 220 is the limit if you are measuring the temp at the stock location. 230 if you are measuring in the upper radiator hose. I plugged a techtom into my car at the convention and my car did read about 10F higher at the upper hose then the stock location. I see 210 all the time on the street and my fans dont even click on until over 210F (all upper hose measuring).
Old 12-21-2003, 09:02 PM   #17 (permalink)
Veritas
Think twice as thick as a stock NX radiator, and you're in the ballpark. I've already shot photos of all three radiators (NX, SE-R, and the prototype) together, and it isn't even a contest in terms of size, capacity, and thickness.
Old 01-18-2004, 07:29 PM   #18 (permalink)
Its Slow
Any details on this rad? Any word on making it work for a B14, Greg?
- Justin
http://www.imagestation.com/picture/...e/f9a9e41f.jpg
http://i149.photobucket.com/albums/s...rley05/b14.jpg
96 SE-R White, BIG turbo
96 SE-R Black, stock mostly
05 Dodge Ram 1500 4 door 4x4, Tow vehicle
Justin is offline   Reply With Quote
Old 01-18-2004, 09:24 PM   #19 (permalink)
Honda Employee...
Greg, where can I get this radiator?
Old 01-18-2004, 11:14 PM   #20 (permalink)
Corporate Bullsh*t
IIRC, it's still in a "R&D" phase right now. Just finishing up the final touches. The seller is still top secret, but the price/quality will be second to none. Good things come to those who wait.
