Go Back   SR20 Forum > Classifieds > Buying / Selling Experiences
Old 08-05-2008, 11:41 PM   #1 (permalink)
Thumbs down JGY Customs Incompetence
The thought of discontinuing the use of service has finally come for me. Every time I have tried dealing with JGY (Jason Garrett Young) has been upsetting. When you are dealing with Jason for the first time, you may be able to get him on the phone. He seems pretty upbeat and knowledgeable as well as interested in getting your business. He agrees with you that your deadline can be met. Ok after the deadline has not been met and past by weeks or parts/built engine has problems that you have received, it is almost impossible to get him on the phone. His front office people, Pam or Scott or whoever working with Pam at that point, tells you that he is either out to lunch or out in the warehouse and you will have to leave a message that they will relay to him. If it is about a delay, you get a number of excuses. Most of the time it will be that a particular part that your order requires is backordered. If everything is place, you motor build fell behind others. Long story short, excuse after excuse creates delays. Honestly I just think Jason is overwhelmed and can’t admit to that he really needs help.
On to my own situation. After numerous delays and missed deadlines, I got my built motor back from JGY more than a month overdue. I don’t know how many of you have received motors from Jason but this is where his incompetence comes into play. Jason will replace head gaskets for you that he believes should not be reused. This is something I actually appreciate because at least I know that I am starting with a new cometic head gasket and he actually returned the old gasket for my own inspection. Of course I found this out when I had to pay my final bill before it was shipped back to me. Like I said, I paid for the build without argument. The big problem is not that Jason will replace $100 head gaskets without discussing it with you first, which again is what I appreciate. The problem is when he uses silicone in places where actual gaskets are used from the factory. This is only the beginning. He even reuses gaskets that should not be used. The gasket on my particular build that I had a problem with is the timing chain tensioner gasket. To give you a better picture of this. I have completed putting my built SR into my ’97 S14. The car is running, new fal fans are working just fine, temps are good. I drive the car down the street to test it. I get it back inside my shop and noticed one small drop of oil. Can’t tell if it is gear oil or motor oil. Look behind the car and even under it as I put it on the lift. No signs other than maybe just a little spilled when filling the tranny. Anyway so I proceed to a mechanic’s shop who is actually a friend of mine and former neighbor when I ran my performance shop. I have to mention my performance shop so that you all know that I very technically inclined and have geared myself up to perform my own builds from now on. Back to my story and on the way to get the AC charged. He is now within 20 minutes of me. I am going to let him recharge my AC. I get to his shop and they are getting ready to charge the AC when one of the mechanics there noticed a puddle of oil under my car. We quickly take a look and notice that it coming from the timing chain tensioner. With a mirror, we can see grey silicone on the back side of the cover for the tensioner. Well we removed it, while maintaining the timing chain position. What we found is that Jason reused the factory metal gasket. The problem lies in the fact that the factory gasket has a rubber ring on it that creates the seal. The rubber ring is completely gone. The evidence looks like Jason only placed literally 2 drops of silicone around the two studs coming from the head. Now I proceed to of course try to call Jason. After a few hours of calls with Pam relaying messages between Jason and myself, Jason’s final answers were that he did not use silicone and that the part was the same as a ’92 SE-R and that I could get it from Nissan. No apologies just stated that he did not use silicone. I am thinking to myself which is worse, lying about not using silicone (only in 2 spots) or the fact that he reused a metal gasket with no rubber seal. After him taking his time putting the motor together he could have spent the less than $10 from Nissan to replace the bad gasket and charge me for it since he decided to replace the $100 cometic head gasket that he did not discuss with me until I got my final bill which I will again say I appreciate his meticulous approach on. Honestly this could have required a lesser experienced tech to have to remove the valve cover and timing chain cover and have to reset timing all over again.
All in all Jason may be good at what he does but cutting corners overshadows your ability and just makes you a simple half-ass. People if you decide to use JGY please make sure that you require Jason to replace all factory gaskets if you have to supply them yourself. If you take a closer look at his work, you will notice that he more times than not will use silicone in place of $5 and $10 factory gaskets. And yes Jason used silicone in place of several other gaskets on this build that are going to be replaced.
z1adonis is offline   Reply With Quote
Old 08-06-2008, 12:10 AM   #2 (permalink)
Trader Rating: 133 (100%)
^^ long read. but i think "many" of us do NOT use them because of there history on here.
thats why i do my own work.
1810 is offline   Reply With Quote
Old 08-06-2008, 12:19 AM   #3 (permalink)
yeah my first expierience with jgy was my last, not a good transaction
B13GFB4 is offline   Reply With Quote
Old 08-06-2008, 12:39 AM   #4 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
They've been blacklisted for years. Literally.
http://www.sr20forum.com/buying-sell...blacklist.html
1992 SE-R 'Fasty' Mods and mods in boxes. Ready for more boost, or more vvl.
Old 08-06-2008, 12:47 AM   #5 (permalink)
bluebird
jgy screwed me on an ecu. they sent me a computer that had 3 bad circuits, the fuel pump the ac and the idle and when i called and talked too jason he told me i had to fork over the 200 dollers to jwt to repair the computer that he was not going to cause he didnt want to be out of the money
b13sr20guy is offline   Reply With Quote
Old 08-06-2008, 01:10 AM   #6 (permalink)
SR20 apprentice
Long read for sure, but a good read. As tempting as some of JGY's prices may be, I will now, without a doubt, never give them any of my hard earned money.
98 Sentra SE: Injen - SSAC - Magnaflow - Stillen - Elemental Designs - Kenwood
Old 08-06-2008, 01:22 AM   #7 (permalink)
and i was thinking of getting some parts there..............good heads up....
Straight1.8 is offline   Reply With Quote
Old 08-06-2008, 01:39 AM   #8 (permalink)
82nd Airborne Boosting
Well I have only bought clutch kits from them and have never had any problems with my orders, but every dog has his luck.
99 Nissan Altima GXE
93 Sentra SER Maroon (SOLD)
92 Sentra SER-T Black with JDM bottom, ACL bearings, BB rods and pistons, NISMO 260cams
My ADT truck
Souljy is offline   Reply With Quote
Old 08-06-2008, 09:04 AM   #9 (permalink)
www.FAIRTAX.org
paNX2K&SE-R's Avatar
Trader Rating: 66 (100%)
This has been a known fact for a looooooong time, NEVER let JGY touch your car and NEVER buy anyhting from them that was made or modified in-house.
usually they aren't too bad for buying stuff thats in stock and that they didn't make themselves though lol.
91 SE-R w/DET
02 G20 Sport 5spd
94 Miata "homobile"
93 240SX Family Project
Old 08-16-2008, 12:34 PM   #10 (permalink)
_______
Mike's Avatar
Trader Rating: 56 (100%)
Because I'm curious tell us what else he used silicon rtv on.
Also the TC tensioner usually has a bit of RTV Grey on the studs from the factory. Not sure why but I've noticed it on more than one head that I have had the pleasure of taking apart. Now this doesn't excuse reusing a $10 worn out gasket by any means but it could explain his jibber-jabber over not using any rtv on it.
Mike
Mike is offline   Reply With Quote
Old 08-16-2008, 12:36 PM   #11 (permalink)
_______
Mike's Avatar
Everyone READ/SEARCH the feedback section before dealing with someone! It's here for a reason!
Mike
Old 08-16-2008, 04:19 PM   #12 (permalink)
SE_R
Well I have personally had good expirience with JGY. I ordered bc stg 2 cams and springs, cometic head gastket, ARP Head bolts all on seperate orders, and I have yet to wait more than 5 days for anything that I ordered from them.
However I have not had them do any work on my car, but to "burn" JGY completely? Well seems to me like they have too much work.
Better luck next time.
Alex_se_r is offline   Reply With Quote
Old 08-17-2008, 07:41 PM   #13 (permalink)
Powered by BABY GODZILLA!
jonwepa's Avatar
Trader Rating: 36 (100%)
I actually had to use both the gasket and rtv to completely seal mine, but I do see your point. Why go all out on one thing and cheap out on a easy cheap part. He probably didn't have the gasket and just cut a corner like you said.
I've bought some stuff and had no problems, but I did notice my stainless oil feed line that i bought from them is leaking a little.....
Old set-up: 91 se-r sr20de+T 13.04@110mph w/ a t25 and s3's
New set-up: 91 se-r gti-r sr20det w/ a gt28r(Something MUCH bigger coming in FEB...),gti-r manifold, MSD 72lb inj., N62 maf, Turbo XS RBV-25 bov, Calum ecu(TUNED BY STEVE), Hallman pro rx mbc, Greddy tt, B&M ss, Greddy FMIC, AEM wideband, Autometer gauges, AGX's on Road magnets, etc.....And it Does run....barely
jonwepa is offline   Reply With Quote
