What is Consult? FAQ - Page 3 - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > CalumSult (Archived for Informational Purposes)
Old 04-04-2007, 05:59 PM   #41 (permalink)
:O c====8
Feedback Score: 4 reviews
I have a greddy E-manage, and i want to hook up ECUTalk to my PDA. if i make changes to the fuel map in E-manage, what will show up when i use ECUTalk? would it show the altered or unaltered signals?
Hanzzzzz is offline
Old 04-04-2007, 07:37 PM   #42 (permalink)
Feedback Score: 8 reviews
altered, same with any piggyback...consult will display what the ecu "sees", and the purpose of all piggybacks is to trick the ecu, so it will show whatever the piggyback is showing it.
NewKleer is offline
Old 04-04-2007, 10:43 PM   #43 (permalink)
:O c====8
so the goal would be for the stock ECU to read 100% on the A/F ratio guage? the e manage only alters input right? not output?
I'm trying to figure this out in my head... would the ECUTalk program be any use at all when trying to tune with a piggyback or would you need the real readings?
Hanzzzzz is offline
Old 04-04-2007, 11:49 PM   #44 (permalink)
consult doesnt show AFR. it can show a rich/lean register, but this is useless for tuning. the "AF Alpha" etc value are just the ECU's internal correction for cruising, etc, and also are relatively useless for tuning
ecutalk would be useful to log data like injector duty cycle (ie, how long the ecu is holding injectors open) vs rpm, AFM (despite afm being corrected by piggyback), but one of the main components you need is a wideband O2 sensor to obtain the real AFR, and a way to log this (eg dyno's by nature log this).
consult is mostly useful for monitoring rather than tuning, but it has its uses in tuning, mainly to check resulting injector duty cycles, and comparing these to AFR to determine whether injectors are maxing out (likewise if AFM is maxing out)
NewKleer is offline
Old 05-03-2007, 10:51 PM   #45 (permalink)
Feedback Score: 15 reviews
ok, so what about the use of the realtime? is that like the consult and a tuner?
and also, so it would be fine to run one of calums daughterboard consults with the safc2 and a boosted motor?
i can build the motor, i can even splice the wires for the ecu.....but when it comes to understanding how the ecu programs work.....that i am havin a difficult time understanding.
13.776 @ 103mph un-tuned! BOOOOST!!!
A'pexi turbo timer for sale
GSpec.com
93specv is offline
Old 05-05-2007, 02:32 AM   #46 (permalink)
the realtime is a tunable ecu, one u dont have to stop and reprogram (but can do it on the fly...similar to how u can tune piggybacks on the fly)
running a daughterboard with safc2 defeats the purpose of a daughterboard - to remap the ecu (and hence anything safc2 can do can be done in a remap, though a bit harder)
NewKleer is offline
Old 05-05-2007, 02:44 AM   #47 (permalink)
k, so i am already lost again.......what do you suggest?
use the safc2 with xxxxx ecu, or scrap the safc2 and start over?
you have AIM?
93specv is offline
Old 05-05-2007, 04:20 AM   #48 (permalink)
safc2 is a simpler solution if you're new to this kind of stuff, and if you arent going for any major modifications (ie stock injectors/AFM etc). just a stock ecu is needed with it
but a realtime ecu would be better if you're going to pay someone to tune it or learn how to do it yourself, particularly if you're going to have major mods (upgraded injectors, afm, etc)
spend a bit of time searching/reading and see if that helps at all - at some point we all knew nothing about cars, ecu's etc. i dont use aim.
NewKleer is offline
Old 05-16-2007, 11:43 PM   #49 (permalink)
thanx man you have been really helpful!!!
so if i were to go with the realtime.....the safc2 would basically be pointless, correct?
how bout just the basic daughterboard and the safc2?
93specv is offline
Old 05-17-2007, 12:04 AM   #50 (permalink)
it would be pointless with either setup, since the whole point of a daughterboard/realtime ecu is that its tunable - ie whatever you would otherwise do with a safc2 on a non-tunable ECU, you can do with a daughterboard/realtime setup (just with a daughterboard it would be harder as you'd have to burn an eeprom whenever you want to make a change)
NewKleer is offline
Old 05-18-2007, 05:26 PM   #51 (permalink)
ah ha.........k, i think i have made up my mind. safc2 for sale!!!! off to the junkyard to buy an ecu to ship to calum. does it matter if it is highport or lowport? i have a highport b13.
thanx again!!!!! you are extremely helpful!!!!
93specv is offline
Old 05-18-2007, 05:46 PM   #52 (permalink)
Pursuit of happiness
Feedback Score: 5 reviews
I even learned something, Thanks guys.
Ed
pathfinder7 is offline
Old 05-18-2007, 09:15 PM   #53 (permalink)
no idea what high/lowport differences are, ask calum in one of his ecu threads
NewKleer is offline
Old 05-23-2007, 05:11 AM   #54 (permalink)
one last thing......i hope
this may sound dumb but i suppose the only stupid question is one not asked.
will i need a laptop for the realtime?
93specv is offline
Old 05-23-2007, 08:01 AM   #55 (permalink)
http://www.sr20forum.com/calumsult/1...rt-manual.html
NewKleer is offline
Old 10-05-2007, 07:12 PM   #56 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
Can someone upload SRtalk as an attatchment here? The link is down when trying to download.
95 200sx
sr20ve
jer_760 is offline
Old 12-28-2007, 01:12 PM   #57 (permalink)
officially a boost addict
Feedback Score: 10 reviews
Originally Posted by NewKleer View Post
windows:
free:
CalumSult - http://www.calumsult.com/calumsu/CalumSult/
-and use the old version for rom dumping (download the full installer, install, then download this exec) -
http://www.calumsult.com/calumsu/Cal...lt%200.08b.exe
ECU Talk - http://www.ecutalk.com
Conzult - http://300zx-twinturbo.com/conzult/downloads.htm
srtalk - http://www.zcontrol.net/Default.asp
Nissan Data Scan - http://home.iprimus.com.au/tkolo/datascan.htm
Datalog Viewer - http://www.blazt.biz/products/dviewer.htm (for datascan logs)
OBD ScanTech Nissan - http://obdscantech.cjb.net/
TECU - http://eccs.hybridka.com/viewtopic.php?t=263
pocket pc:
free:
600$:
ecu extend http://www.xtendperformance.com/ecuxtend/default.asp
mac
ConSultan - http://members.cox.net/epooch
Edit by Calum: Fixed CalumSult link
ecu talk and srtalk don't work anymore...
and what's the difference between the two versions of calumsult?
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
nsusammyeb is offline
Old 12-28-2007, 07:31 PM   #58 (permalink)
ecutalk works for me....
zcontrol site works but srtalk download doesnt
older calumsult exe is for dumping rom (for rest use what comes with the main install)
NewKleer is offline
Old 12-28-2007, 08:05 PM   #59 (permalink)
I open the second calumsult for dumping rom...and it asks which VI to open...wtf is that?
Old 12-30-2007, 01:14 AM   #60 (permalink)
you need to install calumsult full first, then just stick the other exe in same dir then just chose between the two exe's depending on whether you are dumping a rom or not
NewKleer is offline
