What is Consult? FAQ - Page 4 - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > CalumSult (Archived for Informational Purposes)
Old 02-25-2008, 08:35 AM   #61 (permalink)
The Awesome
Any of the free software offer data-logging? I'm really wanting to see if anything's going on with my car.
93 Sentra SE, no R. Cloud White, 150k Miles, all stock, second owner.
Dustin_M is offline
Old 02-25-2008, 10:09 AM   #62 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
CalumSult does. Don't forget to hit the 'on' button on the gauge screen.
Calum is offline
Old 02-25-2008, 07:03 PM   #63 (permalink)
Feedback Score: 8 reviews
yeh ecutalk does also...i benchmarked the datalogging rate of ecutalk (v1.3.2+) and it turned out 3 times faster than datascan using the same number of sensors (datascan seemed to drop quite a lot of packets).
NewKleer is offline
Old 02-25-2008, 09:18 PM   #64 (permalink)
ClamSlut
Calum's Avatar
Yea, I noticed that too.
Calum is offline
Old 04-26-2008, 04:48 PM   #65 (permalink)
Nissan 200SX S14a
Yes, EcuTalk is the fastest logger i have ever seen. I am one of the Beta Testers with a PDA.
With my notebook ECUTalk takes much more entries in the same time as NissanDataScan does.
MichaS14a is offline
Old 04-29-2008, 11:44 PM   #66 (permalink)
where can i buy all i need to run a calum ecu on an s13 ka-t?
Originally Posted by Luke:
Too bad those Autos are shifting faster then you can.
let see it clutch kick better than i can............oh wait. lol
turbonola is offline
Old 05-23-2008, 05:41 AM   #67 (permalink)
i have a calum realtime pcm with full consult and realtime tuning capability, plus tunerpro rt and nissan data scan. can i use nissan data scan with the usb connector(that is wired to pcm) that i'm using tunerpro rt to tune with or do i need the other conector that plugs into the cars grey port. or just a link to info.
pimp02si is offline
Old 05-23-2008, 10:24 AM   #68 (permalink)
ClamSlut
Calum's Avatar
No, you don't need anything else, Nissan DataScan works just fine with the Realtime. When you connect the Realtime you get two new virtual com ports- port A is a standard consult port (point Nissan DataScan or any other consult software to this port) and port B is the emulator (TunerProRT auto detects this port). Follow the QuickStart Guide post, it shows you how to identify which com port is your consult port.
Calum is offline
Old 05-23-2008, 04:22 PM   #69 (permalink)
cool thanks, i'll give that a shot.
pimp02si is offline
Old 05-29-2008, 06:59 PM   #70 (permalink)
Calcum, I picked up a board on ebay and the serial to usb cable. However I can't get the calcumsalt software to connect. Everything is working, the ezconsult can connect, but thats when I change the com port to #8. I know the calcumsalt software lets you pick the port however the menu doesn't drop down. I uninstalled and reinstalled and still I cannot get the com port menu to drop down. Any advice?
boggie1688 is offline
Old 05-29-2008, 08:03 PM   #71 (permalink)
ClamSlut
Calum's Avatar
Are you using Vista or XP? Did you download the full installer?
Calum is offline
Old 05-29-2008, 08:05 PM   #72 (permalink)
calcumsalt? is that some chinese version of calumsult?
NewKleer is offline
Old 05-30-2008, 04:52 PM   #73 (permalink)
Vista full installer...I figured out that I had to run in compatibility mode xp sp2 and run as administrator.
Old 06-10-2008, 06:31 PM   #74 (permalink)
BTCC VE Power
Feedback Score: 16 reviews
i get the same thing as well. I have to open and close it several times to get to to drop down and even then it doesnt work... I have a 20% success rate with this. The other free programs work fine, except srtalk which works to monitor but I can read or log a/f it crashes when it does
I am also not able to view trouble codes on any programs though I am able to clear them.
KL0 P11 Sport
Surround Sound
My VE thread
civicdragon is offline
Old 07-09-2008, 01:44 PM   #75 (permalink)
Feedback Score: 12 reviews
I ve been trying to use the Calumsult software with the cable that came with the Datascan that is USB but it doesnt recognize the ECU can someone can give me some light on this kind of situation.....
payu is offline
Old 07-09-2008, 06:56 PM   #76 (permalink)
what com port is the usb cable? is it the one ur using in calumsult? have u tried other software
NewKleer is offline
Old 06-13-2009, 06:31 PM   #77 (permalink)
I'm having the same problem with a laptop I've used Calumsult on before. On the initialize page nothing will click and drop down unless you go to one of the other pages a few times, and even then it will go down and when I select the correct com port it won't connect. Tunerpro works fine on the same laptop, and I've still got my old laptop that calumsult works fine on.
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
AaroNX is offline
Old 02-27-2010, 06:22 PM   #78 (permalink)
there is a beta of ECUTalk v1.3.5 which adds alerts - define alerts for battery voltage, temperature, injector duty cycle, speed, airflow and RPM, and the gauge will flash (invert colours) and beep if an alert is hit
http://www.ecutalk.com/downloads/ECU...1.3.5_beta.exe
NewKleer is offline
