HOW TO: Burn a rom with the Moates Burn1 - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > CalumSult (Archived for Informational Purposes)
Old 07-21-2006, 07:05 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
I'm going to write a small series of tutorials describing some of the basic stuff involved with rom tuning. This is the first installment in the series, covering how to use the Moates Burn1, my favorite rom burner. I'm limiting this to cover just the Burn1 because I feel that it is the best low-cost rom burner on the market for a user that is only planning on working with the 27SF512 roms (or now obselete 29C256). If your going to work with other chips, there are better burners out there, but for someone who is only intrested in burning the chips on my daughterboard this burner is the stuff. This is what I use on a daily basis, just becuase its so quick and easy, even though I own a much more expensive professional tool. Anywho, feel free to chime in with thoughts or suggestions.
Ok, first off you need to buy a Moates.net Burn1. They are available for $85 here:
http://www.moates.net/product_info.p...products_id=48
Assuming you've just got your burner, you need to download the drivers for it and install it. Moates has a nice write-up on installing drivers, so I'm not going to cover that. Here's their install instructions:
http://www.moates.net/documentation....entation_id=16
http://www.moates.net/documentation....entation_id=15
Now on to the fun... First you need to open your ecu and remove the roms. You do not need to remove the ecu from the car to do this. If I'm swapping roms on a B13 on a regular basis what I do is just attach the ecu to the harness (ditch the metal braket) and leave the top off. That way I can easily reach back and pull the roms, no sweat. If your driving a 240 this is even easier. When you pull the roms, note that the notch on the chip points up towards the handle of the ZIF socket! You must install them the same way. To remove the roms just lift the little handle and slide them out, piece of cake. Try not to touch the legs, static kills! Here's a picture of what the roms look like installed:
Ok, now install the first rom in the Burn1. Again, the notch points up towards the handle, but the rom goes in the very bottom position in the socket! Here's a pic:
Now plug in the burn1 and fire up the moates flash n burn program. Your going to burn the same bin file to each rom. Here's the basic procedure, follow these steps exactly:
1 - Software should detect the burn1. It will say 'found ...' in the little text box.
2 - Make sure your starting address and rom chip is correct! For B13/S13s, this should be 8000 and using the 27SF512 (or 0000 if your using the old 29C256). For B14/S14s, this should be 0000 and 27SF512. You only have to set these parameters once, the software will remember them.
3 - Now load your bin...
4 - Erase the rom (27SF512s must be erased before burning a new bin to them!)...
5 - Program the rom... This will take 3-4 seconds for a B13, and about twice that for a B14.
6 - And finally verify the rom. This goes fast, and you should see 'SUCCESS'! If the rom ever fails to verify, make sure you installed it correctly. If it is installed correctly, discard the rom. Static electricity kills! With careful use, this will never happen. Don't worry, they're tough.
Repeat steps 4-6 for the second chip and your done! Just install the roms (don't forget to push the little lever down) and thats it. Its really very easy and dosn't take very long at all to do.
Calum is offline
Old 07-21-2006, 07:39 PM   #2 (permalink)
The SE-R Sitter
Feedback Score: 12 reviews
You are the Man..
thanks for the write up i'm sure we all need it. Well, I know I will.
SE R Madness is offline
Old 07-21-2006, 10:58 PM   #3 (permalink)
1.6 3/25/06 VE 7/11/06
Feedback Score: 25 reviews
this is a sticky on my computer now, thanks calum (and the b14 dbs pictures are my wallpaper now)
bj200sx is offline
Old 08-15-2007, 03:09 PM   #4 (permalink)
officially a boost addict
Feedback Score: 10 reviews
so both roms should have the same bins on them, correct? and 27sf512 is the chip that is needed (in case spares are wanted.)
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
nsusammyeb is offline
Old 08-15-2007, 10:01 PM   #5 (permalink)
ClamSlut
Calum's Avatar
Yes and yes.
Calum is offline
Old 12-28-2007, 11:55 AM   #6 (permalink)
How can you get the .bins from the chips to the computer...have the .bin files uploaded to your computer from the chips? possible? Button where it says "read chip?"
Old 12-29-2007, 01:03 PM   #7 (permalink)
Feedback Score: 17 reviews
"Read Chip" will load the chip bin into the buffer. Then you use "Save Buffer To File" to move the bin file onto your computer.
billc is offline
Old 09-21-2008, 12:25 AM   #8 (permalink)
Feedback Score: 40 reviews
These don't work anymore
91 SE-R: SR20DE (soon to be stock)
jonwepa is offline
Old 03-01-2009, 09:43 PM   #9 (permalink)
Enemy of the stupid
Feedback Score: 9 reviews
http://www.moates.net/index.php?cPath=51
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
Yellow4g63 is offline
