Rom editor sticky - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > CalumSult (Archived for Informational Purposes)
Old 07-27-2006, 05:07 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
Rom editor sticky
Uh, I'll change the name of this thread and add text tomorrow night, hopefully. This is a place holder.
Rom editor installer:
http://www.calumsult.com/calumsu/romeditor19848e.zip
Rom editor englishized exe:
http://www.calumsult.com/calumsu/rom%20editor.exe
Notes on how to make Rom editor look right:
"I figured it out, go to control panel -> regional and language options. Then click on the advanced tab and in the first pull down box, it will say something like "Language for Non-Unicode programs" in blue at the top. From the pull down list select Japanese. Click ok and it will then say you need to restart your computer, restart it and the program should look like the picture. It worked for me and I hope it will for you guys having problems." _also_ download "japanese for non-unicode programs" if japanese unicode isn't already installed.
Quick guide to rom editor:
http://eccs.hybridka.com/viewtopic.php?t=156
B13 91-93 adr file:
B14 ??? adr file:
http://www.calumsult.com/calumsu/B14_512_E.adr
Stock roms:
http://www.calumsult.com/calumsu/ROMs/
Calum is offline
Old 08-10-2006, 09:11 AM   #2 (permalink)
Luke Pighetti
Taiden's Avatar
Feedback Score: 3 reviews
There is no link for the B13 adr file.
Taiden is offline
Old 08-24-2006, 12:48 AM   #3 (permalink)
MAD GTI PulSSSar
Feedback Score: 7 reviews
http://sr20forum.com/showthread.php?t=95326
ADR Files... Contributers of course
'90 N14 GTI Pulsar, Sr20VE w/Sr16VE cams, Calum Basic, 3" WAI, 2.5" Exhaust, Fidanza Flywheel, Poly mounts, ACT HD, SSAC Header
blo0d is offline
Old 08-28-2006, 01:40 AM   #4 (permalink)
Calum Supporter
Feedback Score: 23 reviews
calum with the rom editor software can you change the rev limit and is it as easy as just entering your injector cc and maf type and it calculates it for you like emanage ,great software and your doing a great job with this stuff
G-Unit91 is offline
Old 09-05-2006, 05:49 PM   #5 (permalink)
ClamSlut
Calum's Avatar
Yes, and no. Injector/maf changes take some figuring out.
Calum is offline
Old 09-05-2006, 06:40 PM   #6 (permalink)
merely a flesh wound
chriscar's Avatar
Feedback Score: 110 reviews
Well I played with the Moates I bought, and I can change the rev limit like a pro! lol
chriscar is offline
Old 09-05-2006, 07:23 PM   #7 (permalink)
ClamSlut
Calum's Avatar
Hey cool, I didn't know you broke down and bought the Moates. Cool!
Calum is offline
Old 09-05-2006, 08:03 PM   #8 (permalink)
slave to the grind
TOOQIKK's Avatar
Feedback Score: 33 reviews
i dont have japense as a choice where can i download it ????TIA
94-XE 4D.... boost in the near future...stay tuned....
THE WEBSITE for all your synthetic oil and filter needs...AMSOIL First in Synthetics
TOOQIKK is offline
Old 09-05-2006, 10:57 PM   #9 (permalink)
_______
Mike's Avatar
Feedback Score: 57 reviews
Go to the regional and language menu click on the languages tab and check the box next to Install files for East Asian languages. After all files are installed (you may be prompted to insert your windows CD to copy files from) you should then have the option to select Japanese from the pull down menu on the advanced tab.
Mike
Mike is offline
Old 09-05-2006, 11:06 PM   #10 (permalink)
Feedback Score: 9 reviews
Just as a side note, I found that some sites that use Java don't work when I set Japanese as the language for non-Unicode programs. You just have to change it back to English and reboot.
I thought this might be useful to someone someday.
Dan_93SER is offline
Old 09-05-2006, 11:08 PM   #11 (permalink)
Is there a post that spells this procedure out? I swear I've read all the posts in the contributer's area and it's still not clear to me. Did I miss a post?
Old 09-06-2006, 09:50 AM   #12 (permalink)
ClamSlut
Calum's Avatar
For a B13/S13 (91-93):
Set both fuel maps to all 1s, except the last couple of columns (leave those at something over 30, it doesn't really matter what). Set your TTPmin to all 0. Start the car. If it is waaaay rich adjust your k-number down. Remember, in rom editor the k-value is in hex (123456789ABCDEF). I like working with nice even numbers, like 8000, and jumping 1000 at a time to start. Adjust until the car will start with no problems. Let the car idle and warm up to temperature. Adjust until when you free rev the car to ~3k its close to 14.7:1. Now let it idle, and ajust the latency until the idle is ~14.7:1. Drive the car (do not get on boost or let the engine get loaded up). Adjust until cruising the car is at 14.7:1. Now paste back in a 'normal' fuel and timing map. Now either guesstimate your TP scales based on your injector size change (this actually works pretty decently) or trace the map and set your upper TP value at a somewhat low boost value (~4psi). Also set your TTPmin to scaled values. Now just adjust your last column (upper TP value) for the timing and fuel curve you want under boost and your done.
For a '94 B13 and B14s, its the same as the above but set the map to 128.
Its a tedious process, but you only have to do it once. Also, with the closed loop turned on you really only have to get it 'close', the ecu will (and does) adjust it from there.
Calum is offline
Old 11-16-2006, 03:53 PM   #13 (permalink)
8000rpm crew
Feedback Score: 22 reviews
Off topic: Can I just re-program a JWT this way??? I say Calum ECU is great, but since I already have a JWT...
VVL Power
gtswrx is offline
Old 11-16-2006, 04:46 PM   #14 (permalink)
ClamSlut
Calum's Avatar
Not directly. JWT uses a daughterboard with a 'scrambled' rom. If you know what your doing you can defeat this. Its easier to just dump the rom from the JWT ecu and move it to a generic style daughterboard, like mine.
Calum is offline
Old 07-17-2007, 02:00 PM   #15 (permalink)
the proof wizard
everytime i try and use the rom editor i get this message, anyone know whats wrong?
run time error '76
path not found
thanx
12sec NA
coryb13ser is offline
Old 07-21-2007, 12:29 PM   #16 (permalink)
I get that also, but only when I try to open it by using the desktop icon. It works fine when I choose to open it from the start menu.
MyRedS14 is offline
Old 07-24-2007, 02:19 AM   #17 (permalink)
the proof wizard
wow, funny your right, when i find it in the start menu it opens up fine.... strange. thank you man
Old 02-07-2008, 04:34 PM   #18 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
Do I use the b13 or b14 adr when working with a 94 b13?
95 200sx
sr20ve
jer_760 is offline
Old 09-06-2009, 12:11 PM   #19 (permalink)
officially a boost addict
Feedback Score: 10 reviews
can't remember how to save the adr file to my computer...forget everytime I reinstall this.
http://www.sr20-forum.com/members-ri...ebs-build.html
U13 SR20DET, Turbonetics 60-1 hi fi .63 ar, Brian Crower Stage 2's, 520cc injectors, .3 bar fuel pressure, n62 maf, log manifold, Tial 38mm wastegate (9lb spring), 3" downpipe-3" VRS Exhaust, PLX Wideband, Calum basic ecu.
Balls to the wall until you see God, wait three seconds then hit the brakes...
nsusammyeb is offline
Old 09-06-2009, 12:12 PM   #20 (permalink)
ok, just remembered right click the link and save target as...got it
