Realtime ECU Quick Start Manual - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > CalumSult (Archived for Informational Purposes)
Old 03-01-2007, 05:46 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
This is a quick manual on how to correctly setup your Realtime ECU before installing it in a car. I'll make a cleaner pdf version of this later, but for now this will do.
Remember, install drivers before connecting ECU!
Web version:
http://www.calumsult.com/calumsu/Pro...t%20manual.mht
Word document:
http://www.calumsult.com/calumsu/Pro...t%20manual.doc
READ THIS - 11-2-2007
Use the version (0074) of EmUtility in the link below! The newer rev seems to have broken the communication with the emulator.
http://www.calumsult.com/calumsu/random/EmUtility.zip
Edit - Link to the newer unified driver for Windows 2000/XP and Vista-
http://www.ftdichip.com/Drivers/CDM/CDM%202.04.06.exe
What to do after this?
Get TunerProRT installed (you don't need to continue to use EmUtil, TP can do everything EmUtil can do)-
http://www.sr20forum.com/realtime-ec...unerprort.html
Check out Consult (Port A)-
http://www.sr20forum.com/calumsult/1...nsult-faq.html
http://www.sr20forum.com/calumsult/1...cing-cool.html
Calum is offline
Old 03-01-2007, 06:04 PM   #2 (permalink)
pwnd
or here's ya a pdf of the file....
http://www.mindless-innovation.com/s...t%20manual.pdf
and to view it, go get foxit reader
http://www.foxitsoftware.com/pdf/rd_intro.php
way better than acrobat reader, lot lighter weight
-Kevin
We are a community
Bowlcut is offline
Old 03-01-2007, 06:14 PM   #3 (permalink)
ClamSlut
Calum's Avatar
Thanks!
Calum is offline
Old 12-01-2007, 02:01 PM   #4 (permalink)
Vista?
It is hard buying a laptop without Vista now. Does this work with Windows Vista? All my XP laptops are dead or dying...
drifterx is offline
Old 12-10-2007, 06:42 AM   #5 (permalink)
Done.
Feedback Score: 27 reviews
yes, works with Windows Vista. I have no problems with mine in Vista.
SR20DEEP MD
05 Armada - Tow Truck
04 Subaru WRX 'goon
Cliff está en línea
Old 12-10-2007, 09:29 AM   #6 (permalink)
ClamSlut
Calum's Avatar
Dell still sells XP laptops. I need to pick up a copy of Vista and document the install procedure for it. Mainly, check the FTDI website for the most current vista drivers (which also happen to be the most current XP drivers)-
http://www.ftdichip.com/Drivers/VCP.htm
I know TunerPro RT and Nissan DataScan work with Vista.
Calum is offline
Old 01-24-2008, 10:45 PM   #7 (permalink)
Feedback Score: 15 reviews
calum,
i am having an issue with loading the initial bin file.
i contacted you via e-mail with no response.
i need some help please.
thanx
13.776 @ 103mph un-tuned! BOOOOST!!!
A'pexi turbo timer for sale
GSpec.com
93specv is offline
Old 01-25-2008, 09:51 AM   #8 (permalink)
ClamSlut
Calum's Avatar
Call me this evening. My cell number is on the order form. Have your ecu and laptop ready and I'll walk you through it.
-Thanks!
http://www.calumsult.com/calumsu/order%20form.htm
Calum is offline
Old 01-25-2008, 10:24 PM   #9 (permalink)
just got in..........looooong day!!!
i just tried calling you, voicemail box is full. hope it wasnt too late.
if i dont hear from you this evening, please let me know another good time to call. i will be up for a while.
~thanx calum
93specv is offline
Old 01-26-2008, 04:56 PM   #10 (permalink)
ClamSlut
Calum's Avatar
Will this evening work?
Calum is offline
Old 01-27-2008, 05:16 AM   #11 (permalink)
Calum is THE MAN bar far!!!!!
Last edited by 93specv; 01-29-2008 at 09:35 PM. Reason: to take foot out of mouth :)
93specv is offline
Old 04-01-2008, 12:29 PM   #12 (permalink)
Is anyone else having a hard time loading the drivers? I can't seem to figure it out.
jholman05 is offline
Old 04-01-2008, 12:46 PM   #13 (permalink)
ClamSlut
Calum's Avatar
Are you using XP or Vista?
Calum is offline
Old 04-01-2008, 02:57 PM   #14 (permalink)
My laptop has 2000, the pc has xp...
Old 04-01-2008, 03:49 PM   #15 (permalink)
ClamSlut
Calum's Avatar
Both should be fine. When you run the unified driver, what does it say? Where are you getting hung up?
Calum is offline
Old 04-01-2008, 06:52 PM   #16 (permalink)
I just dont get the "FTDI CDM driver have been successfully installed" notice. I see the folder in my documents so I guess it loaded correctly, Ill have my ecu tommorow and try hooking it up see if it will recognize it. If I have trouble I'll give you a call tommorow evening.
Old 04-01-2008, 08:14 PM   #17 (permalink)
ClamSlut
Calum's Avatar
I bet it will.
Calum is offline
Old 04-23-2008, 03:50 PM   #18 (permalink)
Vista blows anyways! Horribly slow and annoying, just get a copy of XP and load it up on the new laptop, or do a dual boot setup... it will save you some headaches.
boostin240 is offline
Old 05-28-2008, 03:39 PM   #19 (permalink)
CR VE owner
Guys, just in case remember to confirm if XP drivers are available for your laptop /pc's, as well if any BIOS update/ roll back is required to have Vista or XP installed.
BTW, if anyone needs help with Alienware pc I kind of have some experiece with those.
I will download the files, hopefully soon I can get tuned by callum
speed demon is offline
Old 03-31-2009, 03:33 PM   #20 (permalink)
broken links
The links dont work anymore.
Please help.
Dont forget the
SWWOOOSSSHHHHHHH!!!
zuzto is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
