Check your ECU before you ship it to me - SR20 Forum
Go Back   SR20 Forum > Vendor Customer Support > CalumSult (Archived for Informational Purposes)
Old 09-19-2007, 01:25 PM   #1 (permalink)
ClamSlut
Calum's Avatar
Feedback Score: 26 reviews
In the past I recommended people not attempt to open the ecu case before shipping, but I'm changing my stance on that, especially for B13 ecus. The reason I recommended that is the ecu screws are threadlocked from the factory, and will easily strip. To remove, you need to use exactly the right size screw driver (this is where a Chinese screwdriver will not work), or a the correct phillips head driver in a drill. If the screw starts to strip just leave it alone and let me remove it, I've gotten really good at removing stripped ecu screws.
Anywho, more and more B13 ecus are starting to show up damaged when I receive them. I really really don't like to work on damaged ecus, and prefer good clean cores, especially when installing a Realtime board. Don't waste the $350 on a faulty ecu.
B13 ecus typically suffer from one of two problems: burned traces typically on the ecu power supply circuit, or water damage. The burned traces are generally caused by a fault in a sensor. Error in wiring of an S-AFC or MAF are very common causes. The first place to check is the lower right corner of the ecu on the top side. Look for black marks, and if you can rub your finger on them and your finger comes back dirty you've found one. Sometimes these can be repaired, sometimes they can't. If possible, I prefer to just get a new core.
The water damage is very common on cars from up north (but not an exclusive north problem). I think this is because the floor heater vent is leaking onto the ecu. If you are from up north I would pull the ecu even on a stock car and check for signs of water damage. Common signs of water damage are white streaks on the sides of the case, or rust on the lid of the ecu. This doesn't always mean the ecu is damaged though, often times the ecu seal has worked well enough to keep the moisture out. I think there is a reason Nissan started putting the plastic covers on the B14s.
In both cases I would recommend using a fresh core if at all possible. In both cases the ecu may still seem to function and the car may still run, but I would still try to find a fresh core.
Ok, so what does this damage look like? Well, when you pop the covers (front and back), this is what your looking for (I just happen to have more water damaged ecus right now, I'll snap some pictures of burned ecus as I get them):
This is a good example of a burn mark (this is on the ignition switch power line coming into the ecu) -
And now for water damage pictures. Sometimes water damage is obvious, sometimes its just in one or two spots. Look for green/white build-up near the input pins of the connector. If its light, sometimes it can just be washed off with rubbing alcohol and a q-tip. If there is also black marks the ecu is probably trash.
One last thing, if you end up with a known bad ecu, just throw it away or at least write 'BAD' on it. Don't sell it. Thats just wrong.
Calum is offline
Old 09-20-2007, 05:41 PM   #2 (permalink)
Ser Charles
zerogravity's Avatar
Feedback Score: 5 reviews
Geee..im wondering if mine was one of those....
Yes...if you guys know your ECU is bad..DON'T SELL IT. It's just not right.
www.cfxpaintworks.com
"There is one thing man should truly fear...it is the INDIFFERENCE of good men..."
My Set Up:
Motec Exhaust*Walbro Header*MSD Rims*Jim Wolf Custom Paintjob*Injen Tires*Mugen Glove Compartment*MazdaSpeed Bridgeport*Edlebrock Exhaust Bearings*Calum Power Mirrors.
Damn My Sentra Hauls!!! 93 Whp of PAIN!!!
zerogravity is offline
Old 09-20-2007, 06:43 PM   #3 (permalink)
ClamSlut
Calum's Avatar
Actually yours looked great, with no visible signs of damage. Hang on though, I'm going to have pictures of yours this weekend (hopefully), lots of pretty pictures.
Calum is offline
Old 09-27-2007, 12:05 AM   #4 (permalink)
Travieso Racing
Feedback Score: 6 reviews
i still got that core i gotta send out for you .. i havent forgotten
Danny GDM (HKS)
1993 PRiMERA GT
HkSBlueBird4u is offline
Old 09-27-2007, 12:14 AM   #5 (permalink)
pwnd
hehehe i bet one of them in the pics is the one I got for ya ....oh well i was 1 for 2 on good ecu's
-Kevin
We are a community
Bowlcut is offline
Old 09-27-2007, 01:04 AM   #6 (permalink)
Travieso Racing
FLINT i can see Tron from here... hes goin up against the master computer
Old 10-27-2009, 01:00 PM   #7 (permalink)
Sigfod's Avatar
Feedback Score: 3 reviews
If we post a picture can you inspect it? I have a GTi-R ECU I am going to be sending in once I find it
96 SE-R Totaled in '99
2000 Sentra SE w/ GTi-R 2.0T
2011 X5 xDrive35i Sport Activity
2006 Cadillac CTS-V
Sigfod is offline
Old 10-27-2009, 01:27 PM   #8 (permalink)
ClamSlut
Calum's Avatar
Sure.
Calum is offline
Old 11-01-2009, 06:58 PM   #9 (permalink)
Sigfod's Avatar
Calum,
Please take a look at these and let me know what you think.
Sigfod is offline
Old 11-02-2009, 10:57 AM   #10 (permalink)
ClamSlut
Calum's Avatar
That looks fine. That's a Techtom board btw, what's it programmed for?
Calum is offline
Old 11-02-2009, 11:22 AM   #11 (permalink)
Sigfod's Avatar
This is my spare ECU that I bought specifically to get a real time conversion.
I don't even know how to figure out what program it has.
What is a Techtom board?
Sigfod is offline
