ve bin k-value - SR20 Forum
post #1 of 5 (permalink) Old 06-03-2009, 07:58 PM Thread Starter
NEOVVL
Quoted: 0 Post(s)
Feedback Score: 3 reviews
(Thread Starter)
ve bin k-value
hey calum or anyone who's knowledgeable explain how the k-value in the ve bins was derived?
if the going from 259cc to 333cc injectors with de maf (using 31206 as the stock k-value number, is that correct also?) would the calculation be
24271 = (259cc / 333cc) x 31206?
also as i was searching i found that the ve injector latency is .70ms and the bins have .60ms. is there a reason for this also?
just asking questions trying to learn and understand. thanks guys.
Dave
'93 Nissan NX2000
SHIFT_the lift
SR20VE w/ SR16VE Cams, Calum Basic ECU, 2.5" SSAC Header, 3" VRS Exhaust,
3" WAI, JWT Popcharger, DE MAF, VE Injectors, Ultra Ignition Wires, MSD 8969, Thermoblok Spacers,
Competition Clutch Stage 4 Kit & 9lb Flywheel, B&M Short Shifter, Cusco FSTB, Motivational RSTB,
H&R Springs, ES Mounts, B14 SE-R Wheels, Euro/JDM Rear Brakes, S13 Steering Wheel
speedyd718 is offline
post #2 of 5 (permalink) Old 06-05-2009, 08:39 PM Thread Starter
NEOVVL
Quoted: 0 Post(s)
(Thread Starter)
anyone?
'93 Nissan NX2000
SHIFT_the lift
post #3 of 5 (permalink) Old 06-19-2009, 07:53 PM Thread Starter
NEOVVL
Quoted: 0 Post(s)
(Thread Starter)
any ideas?
'93 Nissan NX2000
SHIFT_the lift
post #4 of 5 (permalink) Old 06-19-2009, 09:15 PM
SE-R Monster
Quoted: 0 Post(s)
Feedback Score: 6 reviews
my personal VE bin uses a k value higher than the calculated # to acheve a good 14.7 afr across most of the rev/load scale (mind you this is with the o2 sensor disabled). i also use .70 lag time for the inj as it seems to have cleaned up my idle over the .60. now my 20ve also is using a n60 maf with N1 cams so that would also make it different then the test car calum used. the k value i have noticed will be different on most cars some close some alot more so due to slight differences in the setup.
2k2 aztec red specv (i/h/e/p/mm)(sold)
92 classic with mods (dismantled)
94 classic rare blue (totaled rearend hit)
91 Black (whole lotta attitude )
My true loves
http://www.sr20forum.com/turbo/158047-my-sleeper-p.html
mr.sentra_specv is offline
post #5 of 5 (permalink) Old 06-20-2009, 07:08 AM
Quoted: 0 Post(s)
Feedback Score: 17 reviews
You are calculating the new K value correctly, but this is just a starting point. Setups differ. I am using a K of 28873 for my SR20VE with SR16 cams, Fuji, and 2.5" exhaust. This value gives me the AFR that I am seeking at idle and through the light load parts of the fuel map. I honed in on this value through empirical testing on the road. My tunes also use .60 latency, I've never adjusted this parameter -- it's just the way that the bin came from Calum.
billc is offline
User Tag List
