Timing? once again - SR20 Forum
post #1 of 8 (permalink) Old 07-14-2009, 08:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Timing? once again
Ok so the bin that I'm currently using has a stock timing map with everything turned down by 5. That means that at idle it should be idling at 10. Which is fine with me at this point. When I use Calumsult it still shows the idle at 15. What would cause that?
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
AaroNX is offline
post #2 of 8 (permalink) Old 07-14-2009, 10:11 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok I went back and looked at the chart. At 800 rpms it's supposed to be at 10. At 1200 rpms it's supposed to be at 18. The cars idling a little over 1k, so I'm assuming that the 15 I'm seeing is just because of the rpm's. I'd still like to get someone's advice on this though.
AaroNX is offline
post #3 of 8 (permalink) Old 07-14-2009, 11:50 PM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
Feedback Score: 26 reviews
At idle it doesn't use the timing map, it uses the seperate idle timing table.
Calum is offline
post #4 of 8 (permalink) Old 07-15-2009, 01:55 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ah ok, I don't see that anywhere lol. So it'll stay at 15 for idle either way huh? Thanks man, I know you rarely have time to fool with this stuff.
Edit: Ok I just found that. The base idle timing charts. I think it had one for in gear and one for neutral. There's no telling what mine see's since I switched to a 5 spd from auto and kept the auto harness lol.
AaroNX is offline
post #5 of 8 (permalink) Old 07-15-2009, 11:08 AM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
It's probably staying in the neutral table if you don't have the neutral switch connected. Watch the neutral flag in nissan datascan.
Calum is offline
post #6 of 8 (permalink) Old 07-15-2009, 12:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I'll do it. Would you tell me AGAIN how to disable the stock 02 sensor? I'm thinking you just unclick the checked box on tunerpro but I wanted to check again before I did anything.
AaroNX is offline
post #7 of 8 (permalink) Old 07-15-2009, 02:43 PM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
Yep, that's it.
Calum is offline
post #8 of 8 (permalink) Old 07-15-2009, 03:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks again.
AaroNX is offline
User Tag List
