N60 maf de everything else - SR20 Forum
post #1 of 62 (permalink) Old 07-22-2009, 12:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok so I put my N60 on, and used the vq table that Ben put in the Bin that he made for me. It's running, but not right lol. For the most part it's just really lean. Is the vq table the same regardless of injectors? Ben said he thought so, but I thought maybe that's what my problem is. Is there anything else that I need to change? Thanks for bearing with me, I'm trying to learn lol.
Oh and Ben Bin Ben Bin Ben Bin.
93 NX2000-7.75@92mph 5SPD SWAP, 2120lbs. JDM Motor, Calumsult Realtime ECU, BC3 cams/gears, CP XTP 9.2:1 pistons, NX DP-100 shot, 333's, N60, Prothane Mounts, ACT Xtreme/sprung 6 puck, Fidanza, PR WAI with JWT POP, 2.5" SSAC, Dynomax 3" muffler, Outlaw Intake Spacers, OEM wires, ngk plugs, UR Pulleys, Walbro 190, ST springs with KYB's, Kinetik KR912, Axis maglites
AaroNX is offline
post #2 of 62 (permalink) Old 07-22-2009, 01:08 PM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
Feedback Score: 26 reviews
Can you post the modified bin?
Calum is offline
post #3 of 62 (permalink) Old 07-22-2009, 03:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I actually can't. The vq table came from this one that Ben made.
http://www.sr20forum.com/rom-ecu-tun...20-aaronx.html
The rest of the bin is actually the tuned V2 with the timing map changed. Well the rev limiter, knock sensor, and 02 sensor are changed too.
AaroNX is offline
post #4 of 62 (permalink) Old 07-22-2009, 03:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
If you have to have the one I'm trying to use, I can use my other laptop, but I'll have to install everything on it first. My old one won't burn anything to a disc anymore, and I've got everything installed on it.
AaroNX is offline
post #5 of 62 (permalink) Old 07-22-2009, 08:21 PM
like a stray puppy
Quoted: 0 Post(s)
Feedback Score: 11 reviews
what i did was take a stock de bin from jrios' post. then a Bin that was for a VE and N60 maf. I just took the VQ table and injector k value and copied them to the stock DE bin. I then double checked the VQ map to my personal 440cc N60 bin and it was the same. Which is why i figured all you had to do was copy and paste the VQ table to change Maf sensors. I will be doing the same when I change to my N62 MAF i just got to find a bin for that
1993 NX2000: Weekend fun car
1990 Accord: New to me Daily Driver
Octave236 is offline
post #6 of 62 (permalink) Old 07-22-2009, 08:55 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I made it home but barely. Wideband shows dead lean most of the time but randomly flashes up to rich but not for long. Anytime you try to give it more than just slight throttle it bucks and tries to die. I checked the voltages and the constant has 14v and the other one was at 1.4 while the car was trying to idle. I'd say around 1,500 rpms.
AaroNX is offline
post #7 of 62 (permalink) Old 07-22-2009, 08:59 PM
like a stray puppy
Quoted: 0 Post(s)
damn send me the Bin you used i'll compare it.
post #8 of 62 (permalink) Old 07-22-2009, 09:23 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I can't now the good laptop is at the shop.
AaroNX is offline
post #9 of 62 (permalink) Old 07-23-2009, 09:02 AM
Quoted: 0 Post(s)
Feedback Score: 17 reviews
Did you also change the K value? When you change the VQ table, the K value also needs to be adjusted.
billc is offline
post #10 of 62 (permalink) Old 07-23-2009, 09:27 AM
like a stray puppy
Quoted: 0 Post(s)
good stuff to know i told him to play with the K value a little.
post #11 of 62 (permalink) Old 07-23-2009, 10:33 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Nope since it's running lean should I go up or down?
AaroNX is offline
post #12 of 62 (permalink) Old 07-23-2009, 11:24 AM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
Can one of you guys e-mail me the bin?
Calum is offline
post #13 of 62 (permalink) Old 07-23-2009, 11:42 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I can in a little bit, what email should I send it to?
AaroNX is offline
post #14 of 62 (permalink) Old 07-23-2009, 11:48 AM
Quoted: 0 Post(s)
Increasing K will increase the AFR across the fuel map in (more or less) direct proportion. Find a bin with the same VQ map and injectors and use that K value. If no bin with the same injectors is available, using a bin with the same VQ map, calculate a change for the injectors (if your injectors are smaller, then K will need to be bigger) and then adjust the K value in that bin and use that number for your K value. All this arithmetic works in direct proportion (injector size, K value, AFR) but let me know if you want help calculating how much to raise the K.
If all this fails, you can estimate the K that you need. For example, if you are idling at 17 with the O2 feedback loop turned off, and you want to bring it down to 14.7, you need to increase the fuel delivery by 14% ((17-14.7)/17). So just multiply your K value by 1.14 and see what that does for you.
One way or the other, you need to get some fuel into your engine before you do permanent damage.
Bill
billc is offline
post #15 of 62 (permalink) Old 07-23-2009, 12:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ok I had to go all the way up to 45000 just to get it in the 15's/16's. Keep in mind as well that the fuel pressure is at 50 lol. Before at idle the a/f was in the 12's/13's.
The fuel pressure is only turned up that high because of the nitrous.
AaroNX is offline
post #16 of 62 (permalink) Old 07-23-2009, 01:31 PM
like a stray puppy
Quoted: 0 Post(s)
wish we were close enough to swap out my MAF with yours. I mean I'm pretty close but don't have a way to get it to you. that seems way to high to not be running rich. are you able to send the bin. put it in the shared section. I still want to look at it.
post #17 of 62 (permalink) Old 07-23-2009, 01:33 PM
like a stray puppy
Quoted: 0 Post(s)
wait I just re-read your statement. you went from 12/13s (rich) to 15/16lean? what was it idleing at yesterday after the swap.
post #18 of 62 (permalink) Old 07-23-2009, 01:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I just drove it to the shop and it's running MUCH better now. Idling at high 14's/low 15's and driving at partial throttle it's in the 13's. I'll see if I can post it in the other section and give a link to it lol.
AaroNX is offline
post #19 of 62 (permalink) Old 07-23-2009, 01:58 PM
Quoted: 0 Post(s)
Yea, that doesn't sound right. Something funny is going on.
billc is offline
post #20 of 62 (permalink) Old 07-23-2009, 02:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
http://www.sr20forum.com/rom-ecu-tun...ml#post2452435
AaroNX is offline
User Tag List
