Calum help on tach problem - SR20 Forum
post #1 of 11 (permalink) Old 07-29-2009, 08:39 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ei I read your articles on tach problems but I cant seem to find the Q457 that I have to replace. I attached pics so you could help me out. I tried checking the voltage for pin 2 which is blue black and it only read .09 Volts. Could you please help me out.
sentrapogi2 is offline
post #2 of 11 (permalink) Old 07-29-2009, 08:42 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
post #3 of 11 (permalink) Old 08-03-2009, 08:09 PM
MAD GTI PulSSSar
Quoted: 0 Post(s)
Feedback Score: 7 reviews
what board is that frm my friend? that board doesnt resemble my b13 board, so im curious as to what vehicle that hails
'90 N14 GTI Pulsar, Sr20VE w/Sr16VE cams, Calum Basic, 3" WAI, 2.5" Exhaust, Fidanza Flywheel, Poly mounts, ACT HD, SSAC Header
blo0d is offline
post #4 of 11 (permalink) Old 08-03-2009, 08:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Im using it in my b13, for my roller rocker. I dont know where it originally came from but Im sure its JDM.
post #5 of 11 (permalink) Old 09-01-2009, 12:07 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Any idea calum?
post #6 of 11 (permalink) Old 09-01-2009, 12:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I got the tach working but I connected it through the distributor and now Its working fine but now I swapped to a digital cluster gauge and my friends told me that I cant use the signal from the distributor and that I should use the signal from my ecu. Is 0.09volts normal for the ecu tach out? because i read the FSM and it said that I should be getting around 1 to 5 volts. Any help would be appreciated thanks
post #7 of 11 (permalink) Old 09-03-2009, 11:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
anythinG?
post #8 of 11 (permalink) Old 09-04-2009, 01:30 AM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
Feedback Score: 26 reviews
The tach output from the ECU is a pull down, it switches to ground. So you won't see anything unless you put a pull-up to something. The cluster has the pull-up built in.
Calum is offline
post #9 of 11 (permalink) Old 09-07-2009, 01:27 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks a lot for the reply, I really appreciate it bro. Nobody knows anything about ecu problems here in the Philippines so I'm gonna document it in a local Nissan forum here. Ill try connecting the cluster and see if i get anything. Thanks again
post #10 of 11 (permalink) Old 09-08-2009, 04:26 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I tried connecting the ecu pin for the tach to the digital cluster and nothing happened. I tried getting a voltage and I got nothing too. Without the cluster connected I get around 0.023v. Im trying to look for another ecu I can borrow and then I'll try it again Is there another way to put a pull up without the cluster gauge?
post #11 of 11 (permalink) Old 09-10-2009, 07:25 PM
ClamSlut
Calum's Avatar
Quoted: 0 Post(s)
Yes, just wire a 10k resistor from the tach line to +battery.
Calum is offline
User Tag List
