95 Nissan 200sx ser w/GTiR Fully Built Motor - SR20 Forum
Go Back   SR20 Forum > Classifieds > Cars for Sale
Old 01-25-2012, 10:39 PM   #1 (permalink)
1995 Nissan 200SX SE-R w/SR20DET GTiR
Rebuilt Motor Has Less Than 5 Miles On It
Head Work:
*Cleaned
*Pressure Tested
*Resurfaced
*ported/polished
*installed valve guides
*opened seats 1mm
*3 angle valve job
*installed valve seats
*set spring height
Head Parts:
*Tanaka Industrial JUN 11.5mm 280degree intake and exhaust RNN14 GTiR Cams
*Supertech Inconel Exhaust Valves 1mm oversized(31.15mm)
*Supertech Stainless Intake Valves 1mm oversized(35.15mm)
*Supertech Performance Dual Valve Springs and Titanium Retainers(Nissan Pulsar GTi-R RNN14)
*Supertech Valve Stem Seals Pulsar GTi-R RNN14
*EPP Bronze Exhaust Valve Guides
*EPP Bronze Intake Valve Guides
Block Work:
*Cleaned
*Honed
*Micro Polished Crankshaft
*Filed Piston Rings for Turbo/Nitrous Use
*Plastic gauge .002
*Installed Crankshaft
*Installed Rods
*Rods/Mains Installed
Block Parts:
*ARP Head Studs
*ARP Rod Bolts
*Cometic Head Gasket Tightened to ~90+ ft lbs
*ACL Calico Main Bearings
*ACL Race Rod Bearings
*Complete New Engine Gaskets set
*Brian Crower I Beam Rods with Brian Crower 625+ Bolts ( 1,600 HP Rated )
*86mm 8.5 compression Wiseco Forged Pistons with Upgraded Wrist Pins
MISC:
*New Lifetime Warranty Alternator
*New WaterPump
*New Fuel Filter
*New Battery ( relocated to the Trunk )
*New Vacuum/Boost Lines
*New Stage 3 Racing 6 Puck Clutch
*New Throw Out Bearing
*New KoyoRad Aluminum Racing Radiator
*2x 10" electric fans mounted to radiator
*JWT Tuned ECU
*444 CC Injectors
*Z32 MAF
*Colder NGK Iridium Spark Plugs
*NGK 10.2mm Spark Plug Wires
*New Turbo Outlet 5 Bolt Gaskets
*Manual Boost Controller
*Turbo-XS Blow-Off Valve
*Garrett A/R60 M24 1-1 54C Turbo
*5 Speed Gearbox ( In Excellent Condition, All Gears Shift/Work Smooth )
*17" Rims with Tires ( 5 Star Black with Red Lip )
*NISMO Racing Seats
*New Engine Ground Wires
*New Ball joints and tie rods
*New Front Struts/shocks
*TEIN S.Tech Springs, for a more aggressive appearance and increased road holding capability
*AEM 52mm Digital Vac/Boost Gauge -30 to 50psi
*3" Straight Pipe
*4" Exhaust Tip with Silencer
*Aftermarket CD Player Radio
*New Aftermarket Speakers in the Back
NO AC and NO Power Steering
CAR RUNS AND DRIVES
asking price is $5,500 or obo
Wiseco Forged 8.5 Compression Pistons with Upgraded Wrist Pins
JUN 11.5mm 280degree Cams
SS Dual Valve Springs/Retainers
SS Intake Valves/SS Exhaust Valves
Engine Assembled
95 200sx ser
rusconnections is offline   Reply With Quote
Old 01-28-2012, 11:35 AM   #2 (permalink)
bump!! Price Drop $5500 or best offer
Old 01-28-2012, 03:49 PM   #3 (permalink)
SE-R SURGEON
Feedback Score: 6 reviews
why dont you just drive it , people are total cheap asses on here and wouldnt pay what you put into it..
2 SE-R'S ARE BETTER THAN NONE
SE-RiousStyle is offline   Reply With Quote
Old 02-01-2012, 12:01 PM   #4 (permalink)
bump price drop 4.5k
anyone have a gaming laptop
alienware m18x/ sager np 7120 etc/ msi gt783
give me some offers and maybe we can make a deal ?
