Old 01-24-2007, 12:12 PM   #1 (permalink)
SE-R Cup #2
KYB AGX Shock Shaft Failure
I thought you guys might be interested in seeing this picture. The shocks were about 2.5 years old and used with a 375/300 GC setup. For the last 2 years, they only saw daily driving duties. I noticed that the car had started bottoming out in the rear recently. This is what I saw when I took off the wheel!
http://srwadet.merritt.org/v/200SX/IMG_1692.JPG.html
The shaft broke at a groove where the shaft diameter increases.
Wade is offline   Reply With Quote
Old 01-24-2007, 12:18 PM   #2 (permalink)
Is an SE-R/VE a VE-R?
OW. Must be those Virginia roads - I took my hyperco/agx'd' B13 up there recently to play with my kid in Richmond; I've been down here (Atlanta) for six years, but I will NEVER complain about the condition of city roads down here again. Richmond must not have filled a pothole since I left. So much for tax cuts: no $ for infrastructure.
'93 B13, etc.
do it over and over again?
Old 01-24-2007, 01:22 PM   #3 (permalink)
DBA/IT
Trader Rating: 19 (100%)
wow... hope you got home ok
http://www.rollyourcar.com
Old 01-24-2007, 01:23 PM   #4 (permalink)
wants to go play
Blair's Avatar
Wow, that's the second car I've heard of doing that.
93 SE-R (daily driver)
Old 01-24-2007, 01:27 PM   #5 (permalink)
Drinking The H Juice Now
BigB's Avatar
That sucks, good to see you managed to get it home.
1992 SE-R WHT - SOLD
1992 SE-R BLK - R.I.P.
2001 -Mazda MP3 #60 of 1500
1991 Integra LS -
BigB is offline   Reply With Quote
Old 01-24-2007, 01:28 PM   #6 (permalink)
Tired!
coach's Avatar
Trader Rating: 42 (100%)
That is NUTS man. I have never seen an AGX strut do that and I have prolly installed 4 sets on friend's cars. Crazy.
Brent
coach is online now   Reply With Quote
Old 01-24-2007, 01:32 PM   #7 (permalink)
Leggo of my eggo.....
Perhaps the rear bushings are shot and it's causing the strut to move around enough to snap the shaft? Or maybe you're torqueing the top shaft nut a little too tight? Perhaps it's a little of both? Just throwing out ideas....
Hammerin Hank is offline   Reply With Quote
Old 01-24-2007, 01:35 PM   #8 (permalink)
SE-R Cup #2
I probably drove it about 600 miles in that condition!
Old 01-24-2007, 01:36 PM   #9 (permalink)
employed again
[Stan] That's pretty f#cked up right there[/Stan]
Matt
MaddMatt is offline   Reply With Quote
Old 01-24-2007, 01:46 PM   #10 (permalink)
SE-R Cup #2
I don't think so. I replaced the suspension with a new hyperco/agx setup. The mounts were in good condition. The top shaft nut does not apply load to that part of the shaft.
Old 01-24-2007, 02:09 PM   #11 (permalink)
BigB's Avatar
Well at the very least KYB should replace under warranty.
Old 01-24-2007, 02:19 PM   #12 (permalink)
Trader Rating: 70 (99%)
that new setup i sold you will DESTROY the GC combo you had.
Originally Posted by ~KnuckleDuster~
WTF is this suck everyone off thread?
Originally Posted by STRATTON
dont be bent out of shape cause u didnt get a e-blowjob.
FarmBoss is offline   Reply With Quote
Old 01-24-2007, 02:20 PM   #13 (permalink)
SE-R Cup #2
I filled out the contact form on the KYB website and asked if they wanted to inspect the failed components. I never heard back from them. Coilovers void the KYB warranty so I just ordered new ones (my 3rd set). KYB did replace my first set under warranty. However, Stranos never reimbursed me for my replacement costs (AVOID STRANOS!). Looking at the failure surfaces, it appears that it was a fatigue failure which initiated at a defect at the groove. The crack slowly grew about 1/3 of the way across the shaft until the shaft fractured completely. I may get a friend to put it on the SEM to take a closer look.
Old 01-24-2007, 04:26 PM   #14 (permalink)
The smooth funky classic
brokeser's Avatar
OOOH SNAP!!! That sucks bro'
L
brokeser is offline   Reply With Quote
Old 01-24-2007, 04:27 PM   #15 (permalink)
BigB's Avatar
Originally Posted by brokeser View Post
OOOH SNAP!!!
Literally.....
Old 01-24-2007, 07:40 PM   #16 (permalink)
YOUR F0RUM SUX
wow... that is just not good at all.. you seriously could have rolled your car EASY to avoid something.
Sentrixx is offline   Reply With Quote
Old 01-24-2007, 07:48 PM   #17 (permalink)
Stop buying AGX, get Konis
-Jon
Daily driver: 98 Maxima SE ... Koni, Ground Control, Stillen, Enkei, Falken, Warpspeed, 14.9@95.
06 Drag car: 91 Sentra SE-R ...Lowport, U12 turbo kit, gutted, on a budget, 247whp@10psi, 13.1@110. TOTALLED.
08 Drag car: 94 Sentra E ... Built lowport, T3/T04E, gutted, still in the making.
JSutter is offline   Reply With Quote
Old 01-24-2007, 08:09 PM   #18 (permalink)
egg-less
Seriously, the roads/streets in Richmond proper are as bad (or worse) than those in Minneapols/St. Paul. Apparently, none of the road crews around here know what a pavement transition is.
al
aknapp is offline   Reply With Quote
Old 01-24-2007, 11:19 PM   #19 (permalink)
cut the fat
AGXs are fine. every company has defects. even koni.
featherweight13 is offline   Reply With Quote
Old 01-24-2007, 11:26 PM   #20 (permalink)
XxToKeSxX's Avatar
yikes... for the record, what were your dampening settings at?
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
