Originally Posted by Fosters
I believe Serban ran a GB on them. You could also see if GregV can source them. I think I ordered my from TrueChoice way back in the day.
Josh
Yes. Stick with Forum Vendors if at all possible.
If not, Tire Rack sells them and a full line of Koni products.
I'm running AGX's with Hypercos. I used the Koni bumpstops as pictured in the Suspension Thread. I did not cut mine. The Koni is a
progressive bumpstop. It gets harder to compress, the more you compress it. I cannot tell if/when I hit my bumpstops unless I really,
really, hit a major road irregularity. It doesn't happen very often in DD, once every couple of months I "test" the Koni bumps.
