energy suspension vs koni bump stops? - Page 2 - SR20 Forum
Old 08-19-2007, 01:34 PM   #21 (permalink)
Originally Posted by 98sr20ve View Post
In your shortravel setups a bumpstop becomes a extension of the primary spring. You will hit it. Difference becomes how progressive/hard the transition is from the main spring to the bumpstop. Koni are softer and ramp up to the end of travel in a smoother fashion.
If Firehawk racing we used to have nearly alll of the travel into the koni bumpstop since we could not change the spring.
2006, The year of the Dog Car
choaderboy2 is offline   Reply With Quote
Old 08-19-2007, 06:01 PM   #22 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
Great thread, great discussion on bumpstops.
Just got included as a link in The Suspension Thread:
http://www.sr20forum.com/driveline-t...ml#post1651579
Old 08-19-2007, 08:05 PM   #23 (permalink)
Feedback Score: 12 reviews
I knew this thread was headed that direction.
Steve
06 G35 6MT
Old 08-19-2007, 08:06 PM   #24 (permalink)
Did you just use a really long bumpstop? Or Multiple? Or lowering springs (spec racing approved?) that settled to the bumpstops?
Old 05-22-2010, 02:46 PM   #25 (permalink)
Is that wrong??
vqman's Avatar
Feedback Score: 20 reviews
ah crap, I didn't get those white discs with my koni bump stops that came with my last set.. does anyone have an extra set sitting around?
1991 | black | SE-R
bridgestone potenza RE-11's | hypercoil gen ii springs | shortened koni struts | ST front sway bar | octotat 3 point RSTB | octotat 2 point FSTB | ad22vf calipers | carbotech pads | sr20ve | n1 cams | jk nemu rt | hotshot cai | ssac header | 2.5" mandrel bent exhaust | wrx STi muffler | jwt motor mounts |
SR20DEEP MidWest Chapter
vqman is offline   Reply With Quote
