energy suspension vs koni bump stops? - SR20 Forum
Old 08-16-2007, 11:24 AM   #1 (permalink)
KASSANOVA!!!
Feedback Score: 47 reviews
need to know if anyone has good experiences with the energy suspension bump stops on their b13 with agx's. reason is because i need two complete sets, totalling 8 for my two b13. energy suspension ones would be only 60 plus shipping for all 8, while the koni's will be roughly 160 or so plus shipping. a third of the price for two sets, but are they a third of the performance of the koni's?
92 Dark Gray Sentra SER
92 Red Sentra SER
Old 08-17-2007, 03:32 AM   #2 (permalink)
KASSANOVA!!!
any help please? new suspension is gonna be here in a few days and i gotta make a decision???
Old 08-17-2007, 08:54 AM   #3 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Feedback Score: 53 reviews
I'm rusty on my standard damper info, but I believe you only need Konis in the front due to the limited suspension travel in the front. The rear is not as bad.
You said you are running AGX, but with what spring setup? That will dictate your decision more.
In my case, I will be running 380 F & 350 R on my NX teamed with shorted Koni's. Based on what I was told, my springs will coil bind before my dampers bottom out - so I'm running ES bumpstops.
I do have Koni's on the front of my AGX/Hyperco 2 setup that is on the car now. For standard lowering springs I would run Koni's in the front - that's my $0.02.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit - For Sale
Old 08-17-2007, 12:13 PM   #4 (permalink)
KASSANOVA!!!
running agx with road magnets. i know the koni bump stops are the best choice, but wanted to know if the energy suspension ones are good also. like i said, only a third of the price of the koni's.
Old 08-17-2007, 12:24 PM   #5 (permalink)
Feedback Score: 12 reviews
Not even close. I would use oem rubber before I spent a dime on ES bumpstops. ES is hard rubber. Some of the OEM are nice foam. Shoot, a lot of VW oem stuff is way better then ES and nearly free at a self pull place. Nissan-VW and others have all used a foam bumpstop at one time or another. Koni is a nice NEW foam bumpstop. ES is hard rubber/urethane (whatever it's hard). Nissan used a rubber bumpstop on my 98 but I have seen some oem B13/Maxima stuff that is actually pretty nice. Get Koni or junkyard some foamish stuff from a junkyard.
Steve
06 G35 6MT
Old 08-17-2007, 12:30 PM   #6 (permalink)
Also if you choose ES cut a V into the section that would hit the damper. That way it can't create a vacuum and force air into the damper or suck air out of the damper. Koni supplies the discs with its shocks/struts to prevent this from happening but AGX doesn't.
Old 08-17-2007, 12:31 PM   #7 (permalink)
Retired for now...
Feedback Score: 21 reviews
koni ftw!
were a community not a ad site.
U12BBDreamer06 is offline   Reply With Quote
Old 08-17-2007, 12:53 PM   #8 (permalink)
1/4 MILLION MILES STRONG!
Feedback Score: 5 reviews
I just paired my agxs up on my B14 with konis all around. The ride is great.
SE-L SLEEPER
Tuned GXE is offline   Reply With Quote
Old 08-17-2007, 02:37 PM   #9 (permalink)
If you have a ton a travel the Koni Bumpstops are extra icing on the cake. But any drop spring with a AGX can really benifit from the Koni Bumpstops. Of course for the price of the bumpstops you can just Skip AGX's and get Koni's and shorten them yourself. Then you wouldn't need the bumpstops unless you like the icing
Old 08-17-2007, 02:47 PM   #10 (permalink)
Retired for now...
Im afraid to shorten them my self...
Old 08-17-2007, 03:00 PM   #11 (permalink)
Cookin Up Some Snails
Feedback Score: 17 reviews
KONI BS , FTW.
rodrigo is offline   Reply With Quote
Old 08-17-2007, 03:23 PM   #12 (permalink)
Don't be SCARED. Just follow the directions and don't do anything you can't undo with out posting if you have a question.
Old 08-18-2007, 02:03 AM   #13 (permalink)
Feedback Score: 23 reviews
So THAT'S what those are.
"I'm sorry, we were talking about chocolate?"
kioh is offline   Reply With Quote
Old 08-18-2007, 02:45 AM   #14 (permalink)
And pack dirt into the seals and even push it all the way into the damper itself.
2006, The year of the Dog Car
choaderboy2 is offline   Reply With Quote
Old 08-18-2007, 02:46 AM   #15 (permalink)
Koni foamies are the best.
Old 08-18-2007, 08:11 AM   #16 (permalink)
Parting out my car
Feedback Score: 25 reviews
I got RM springs (buy1) on AGX, Konis cut to 40mm, work well on my B13.
My front drop is a bit too much anyways.
Slow is the new fast
Old 08-18-2007, 09:45 AM   #17 (permalink)
Never thought about that part of it all. Of course I ran Koni's on all my Nissans with the Koni supplied disc so I never gave it a second thought.
Old 08-18-2007, 06:29 PM   #18 (permalink)
Is an SE-R/VE a VE-R?
Sorry haven't read thread before. EVERYBODY swears by the koni stops. I personally (B13 VE, Hypercos, AGX, Progress bars, Stillen front & AT rear braces, AD22vf's, nx2k bias valves, 205-40/16's) used the AGX boot/stop pieces on the front. I'm kinda prone to keeping things together for along time, liked COVERING the rods. Duh. I'm an inch shorter than stock Hypercoils (LONG discussion with the engineer who designed the Hypercos), so I find the stops even with front AGX set at 3 with some regularity. The AGX stops work JUST fine, thank you very much. AND they keep the crap off the rods.
'93 B13, etc.
do it over and over again?
Old 08-19-2007, 12:13 AM   #19 (permalink)
In your shortravel setups a bumpstop becomes a extension of the primary spring. You will hit it. Difference becomes how progressive/hard the transition is from the main spring to the bumpstop. Koni are softer and ramp up to the end of travel in a smoother fashion.
Old 08-19-2007, 04:38 AM   #20 (permalink)
KASSANOVA!!!
guess i'll gotta go junk yard huntin for some then. i need dust boots too, so maybe just get 8 fronts? 160 plus shippin, gotta decide...
