Lower Control Arm Braces - SR20 Forum
Old 09-18-2007, 12:38 AM   #1 (permalink)
Enjoying the Ride
happynole's Avatar
Feedback Score: 85 reviews
After an unsuccesful attempt at using a Cusco 4 point lca brace: http://www.sr20forum.com/general-sr2...ml#post2110438
I was motivated to install my Progress 3 point brace. I have had this in a box since the group buy over a year ago. Installation was actually pretty easy, since I already had the car on the lift to remove the battle scarred Cusco unit. Used a tripod to support the crossmember, and and attached the center bracket using the crossmember rear support bolts.
Kimmie took that pic laying on the floor looking straight up.
Adjusted the end links as instructed and used the new longer lca bolts and locknuts provided by Progress.
Clearance is good around my wrapped 2.5" downpipe. You can see the Progress front sway bar and lca brace almost touching the header on both top and bottom. Clearance would be better without the wrap, but it still just clears by about 1/4" on both top and bottom. I think a 3" downpipe might rub, I'll post up pics when I finish my SE-R. It will have a VE with one of Charles headers which has a 3" collector.
No chance of road interference here
Even though I sell Cusco products, if you have a B13 I can't see any reason to go with any other lower control arm brace than the Progress piece.
Vail White 93 SE-R......................what's a Sunny?
Pearl White 95 Primera.................the Yin to Sunny's Yang
Life is a Journey, Enjoy the Ride
SR20DeepSouth
http://www.datsun.org/roadster/liter.../dream_grg.mov
happynole is offline   Reply With Quote
Old 09-18-2007, 01:20 AM   #2 (permalink)
Feedback Score: 22 reviews
Wow, never realized that the Progress piece tucked so nicely behind the crossmember. Good luck trying to squeeze the Freak Header through the gap ***...
Though the forces on that brace will be higher than those that affix to the front of the control arm bolts, it's a pretty decent compromise of functionality vs. clearance!
_SHig
SHigSpeed is offline   Reply With Quote
Old 09-18-2007, 04:58 PM   #3 (permalink)
wants 2 dry hump chriscar
Feedback Score: 8 reviews
i beleive this is the one i will be going with in the future. if need be i will massage the 3 inch down pipe with a body hammer.
Old 09-19-2007, 10:34 AM   #4 (permalink)
Feedback Score: 27 reviews
Can someone please set up a group buy for the Progress Lower Control Arm Brace for our B13s please? I know we can get them through Greg V. Wasent there a group buy a while back?
Sentra GTR-1 is offline   Reply With Quote
Old 09-19-2007, 04:34 PM   #5 (permalink)
Enjoying the Ride
happynole's Avatar
Yeah, there was one 2 years ago......when I bought mine!!
Old 07-07-2009, 10:42 AM   #6 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
bump it up.........
Joe, do you still have this setup on the NX? If so, does it vibrate in the higher RPM range?
Bend But Don't Break
Old 07-07-2009, 12:23 PM   #7 (permalink)
OI!
Feedback Score: 11 reviews
How big of a difference does this brace make? I was thinking about getting one
"It's not a question of where he grips it! It's a simple question of weight ratios! A five ounce bird could not carry a one pound coconut."
msamusick is offline   Reply With Quote
Old 07-07-2009, 12:48 PM   #8 (permalink)
Turd Furgeson
Benito Malito's Avatar
Feedback Score: 41 reviews
I'd also like to know if there's a lca brace that will clear a 3" dp.
1992 SuperBlack VVL SE-R
1994 P10 KL0
2004 Forester XT SGM
Old 07-07-2009, 01:01 PM   #9 (permalink)
Hostile Aberration
Shawn B's Avatar
Feedback Score: 10 reviews
Joe,
I've got the Progress LCAB.
Have you upgraded your exhaust hangers (Kartboy, Nismo) to help with the clearance issue?
I upgraded to Nismo hangers and got a ton of clearance with my 2" SSAC, which rubbed/vibrated before I replaced the hangers.
With the upgraded and much stiffer Nismo hangers, I have at least 1/2", maybe 3/4" clearance all around my secondary.
I would *guess* that clearance will be tight with a 3" secondary, but will still fit. Key word "guess."
Old 07-07-2009, 02:27 PM   #10 (permalink)
Enjoying the Ride
happynole's Avatar
I have no lower brace on either of my cars right now. There is no chance a 3" will clear. I have someone working on a possible solution and will post more information as it becomes available.
Old 07-07-2009, 04:27 PM   #11 (permalink)
Feedback Score: 3 reviews
The progress LCAB will not clear a 3" downpipe, but I know the whiteline LCAB is supposed to clear. There are some posts that show it clearing, but I don't remember the link.
Breaktackle25 is offline   Reply With Quote
Old 07-07-2009, 04:34 PM   #12 (permalink)
Weekend Warrior
whiteline 4 point brace / off toipc from progressive bars.
^There are two designs for the whiteline 4 point brace. One clears and one hugs.
Part # KSB713 = B13/B14 hugs!
Part # ? = RNN14 clears.
^The RNN14 brace can be ran on B13/B14's as well.
http://www.sr20-forum.com/suspension...-question.html
^Check out this link. For more info, get into with forum member octotat. I believe he did a group buy on the whiteline braces.
http://www.sr20forum.com/group-buys/...ces-redux.html
^Here is the old octotat group buy run.
Old 07-07-2009, 09:58 PM   #13 (permalink)
Enjoying the Ride
happynole's Avatar
We are trying to get something constructed that won't hang down like the Cusco (or whiteline) did. I bent the sh*t out of mine within a week.
Old 07-08-2009, 10:29 AM   #14 (permalink)
Hostile Aberration
Shawn B's Avatar
Originally Posted by MR-4Door-SR20DET View Post
^There are two designs. One clears and one hugs.
Part # ? = RNN14 brace clears.
OK.
A possible Overkill Engineering Motorsports lower control arm brace?
Old 07-08-2009, 01:21 PM   #15 (permalink)
Enjoying the Ride
happynole's Avatar
Old 07-08-2009, 01:26 PM   #16 (permalink)
Weekend Warrior
^Jacked on juice!
Old 07-11-2009, 07:10 PM   #17 (permalink)
PTE billet wheel pimpin
nissan crazy's Avatar
Feedback Score: 7 reviews
how would 3inch do if you ovald the pipe a little ??? because I have the brace ...never installed it , we where just going to masage the pipe to fit in there , or try to
SR20deep PNW
26k original mile NX2000 516whp 18psi on pump Lovefab , O2induction , AEM EMS ...VE head turbo ...all check ...holly crap this stuff makes some POWER ...
B14 daily budget project hopefully it will have a turbo soon ...
nissan crazy is offline   Reply With Quote
Old 07-11-2009, 09:38 PM   #18 (permalink)
Sorry for slightly off-topic, just tried to help out Benito. It would be nice to have some sort of LCAB made that wouldn't introduce ground clearance issues
Old 07-12-2009, 08:59 AM   #19 (permalink)
Turd Furgeson
Well it looks like there is going to be one or two new solutions. That's good. I might try the progress piece and massage it a bit. Any lcab is going to have ground clearance issues. I had the whiteline for awhile and ditched it when I went turbo mostly to recoup a few bucks. It had a few scrapes but I didn't hit it a lot.
Old 07-28-2009, 08:51 PM   #20 (permalink)
OI!
Anyone? I just installed whiteline sway bars, cusco fstb and active tuning rstb and would like a lil more stiffness but can't afford to throw money away...
