Old 09-22-2007, 12:46 AM   #1 (permalink)
300zx caliper and Q45 disc
Can anyone confirm if both can be used together? I have a set I would like to try and install on my P11.
mayhem is offline   Reply With Quote
Old 10-10-2007, 03:10 PM   #2 (permalink)
I LIKE NISSANS
The caliper will work im not sure if the disc will it might be too big. I used a q45 caliper with an 240sx drilled and slotted rotor before on a p10.
spida is offline   Reply With Quote
Old 10-10-2007, 03:44 PM   #3 (permalink)
SR20DEviant
Trader Rating: 23 (100%)
Doesn't the Altima caliper fit on a P10-P11? There is a write up on Z32 NA calipers with Altima rotors and Altima MC. They were fitted on a B13 with new knuckles and such. The P10-11 knuckles might save that step. Read up and let us all know.
Originally Posted by Serban View Post
1991 SE-R -- SR20VE - Hot Shot intake w/ Pop charger, Megan cat-back exhaust, SSAC headers, 2000 SE disc, ACT HD pressure plate, B&M shifter, ADV22 brakes w/ SS lines, FSTB & RSTB, ES sway bar bushings F/R, & Prothanes
PhorB13 is offline   Reply With Quote
Old 10-10-2007, 04:15 PM   #4 (permalink)
Z32 300ZX come in two flavors 26mm and 30mm
G50 Q45 come in one flavor 28mm
Both use 11in diameter front rotors
UNISA JECS is offline   Reply With Quote
