Old 09-22-2007, 12:44 PM   #1 (permalink)
CleanSE-R
Pâté Performance...
FSTB Pull in or push out?
What is the best set up for a FSTB? Should it push out on the towers or pull in on the towers? Does it even matter?
Home of the low (Original) Mileage B13
1992 B13 SE-R - Original Owner. 66K
2004 Avante XD2 GT - DD
2000 Miata LS - Top Down Fun!
MY SIG PIC ------------> http://i34.photobucket.com/albums/d1...31/SE-REGT.jpg
Originally Posted by Octave236 View Post
Uh i believe your contridicting yourself. B13's are highport motors unless a lowport was swapped in.
CleanSE-R is offline   Reply With Quote
Old 09-22-2007, 12:59 PM   #2 (permalink)
Johnny wangwang
The ELITE NX2k Bredren!
Trader Rating: 26 (100%)
I push mine out. Think about it. Its a brace to keep the chassis from flexing during hard turns. Pushing out will keep it from flexing. Pulling in will make it want to flex more.
1993 Nissan NX2000
w/ 1998 SR20DET Avenir motor w/ so many mods it would be stupid to list them all and more coming!!!!!
Johnny wangwang is offline   Reply With Quote
Old 09-22-2007, 01:19 PM   #3 (permalink)
gtlaw
SE-R Newbie 4-life
I would try to pull it in as little as possible either way its going to brace, but pushing out is going to cause positive camber
gtlaw is offline   Reply With Quote
Old 09-22-2007, 02:03 PM   #4 (permalink)
Johnny wangwang
Pushing out isnt going to cause possitive camber. The camber slack is in the strut bolts that connect the strut to the hub.
And really...if your pushing the struts outward thats going to be pushing the hubs top inward (so little that it wont make a difference) which is going to give you NEG camber....
Old 09-22-2007, 03:49 PM   #5 (permalink)
EPSentra
Uh,,, backwards there. gtlaw is correct but it'd be a very small difference either way unless you are really cranking the pressure to it.
EPSentra is offline   Reply With Quote
Old 09-22-2007, 09:48 PM   #6 (permalink)
CleanSE-R
Pâté Performance...
My logic would say have it set to push out. This to me would be more of what a "brace" does...
