Old 10-06-2007, 06:53 PM   #1 (permalink)
...driv'n like I stole it
Good source for front spindle B14 new/used?
Coles notes: Need a spindle that is good for a decent price.
Well, correct me if I'm wrong, but I get the feeling these cars are weak in terms of design when it comes to the front hub/bearing/spindle assemblies. This is my only complaint (other than the noisy Hitachi starter that I replaced a few years back).
I replaced the front bearing with the aid of a press with a new Nissan one, and sure enough, it seems the front spindle bearing seat is worn and the outer race dances in there (you can shake the wheel as if it's loose) - the tie rod, ball joint, and strut mounts are good, and the bearing was tightened to the right torque.
I am a bit afraid of buying a used one and it not being good, etc., i.e. don't know if they test them (used parts places), but I guess some places warranty them? I called a local dealer and got a price of around $350-450 CAN (which is the same as US now) and nearly sh*t my pants. I'd like to buy new for peace of mind, ut would need a good source where shipping would be justified. BTW, would the dealer price include the hub and bearing? Sorry for the long post...
Paulo
'95 200SX SE-R 5-speed
Pfsantos is offline   Reply With Quote
Old 10-09-2007, 09:15 PM   #2 (permalink)
Sr20's Get u Laid
Trader Rating: 21 (96%)
i just ordered mine new front left/right oem hubs with bearings and seals pre installed and pressed ready to install for around 350ish shipped...........
Greg from gspec can get them............
____________________________
|................JDM......................| ||
|........Parts From Japan.............||'|";,
|_..._...____________======||_|_|...,]
s132nr is offline   Reply With Quote
Old 10-10-2007, 09:25 AM   #3 (permalink)
Da*n! Just bought one used yesterday for $60 CAN plus tax. It does come with a 30 day warranty, but one cannot compare with new, especially considering how well the $CAN is doing.
Funny thing is, I was on Greg's site and didn't see it. I guess he can get other stuff not listed too.
Old 10-10-2007, 09:49 AM   #4 (permalink)
Seeing red
JimR's Avatar
Some people are claiming huge miles out of wheel bearings on our cars. They can't be much worse than most cars from the time.
Contamination issues have run me through a lot of wheel bearings. A tear in one of my G20's front wheel seals let water and grime into the bearing and killed it in short order. Also, my '92 SE-R was missing dust caps over the rear bearings when I bought it, and I went through several sets none the wiser.
I also had a front hub fall off the SE-R when I unbolted the axle nut. This was at 180k miles, after years of autocross, street, and trackday abuse. No seal wear, so I can only point to age and hard use. Fortunately, I had bought some spindles and hubs off a junkyard 1.6L B13 Sentra and rebuilt them with fresh bearings and seals a few months prior.
I don't see the need to buy replacement front spindles unless you have bad gouges in the lips where the seals seat, or just want spares to rebuilt. If the bearing presses tightly into the spindle, it should be good to go, right?
1992 SE-R / 1993.5 G20
JimR is offline   Reply With Quote
Old 10-12-2007, 10:45 AM   #5 (permalink)
Nissan Mut Car...
Bought the whole spindle from a local junk yard for 70 bucks... hasnt worn out on me since!
Chris Gault
1995 B14 Turbo 200sx SE-R
"You might think your hot sh*t in a champaign glass, when your really just cold diarrhea in a Dixie cup...."
NaLLa8705 is offline   Reply With Quote
Old 10-12-2007, 02:21 PM   #6 (permalink)
Sr20's Get u Laid
some parts are not on there *** their special order but he can get just about anything u need.......he's the man to go to
Old 10-12-2007, 02:22 PM   #7 (permalink)
Cookin Up Some Snails
Trader Rating: 16 (100%)
I have a used set of spindles of a B14 .
PM me with an offer.
rodrigo is offline   Reply With Quote
Old 10-16-2007, 05:34 AM   #8 (permalink)
YOUR F0RUM SUX
Rod I will PM you... I need to talk to you about them.
Sentrixx is offline   Reply With Quote
