Old 10-23-2007, 01:35 AM   #1 (permalink)
featherweight13
cut the fat
Progress rear bar issues
This is for a 92 sentra. Ive been having issues with the ends of the bar hitting my lateral links. The L-brackets keep turning and ending up in 45 degree angles after driving for a bit. I used 2 jacks to load the suspension when re-installing it however now the left side hangs down further than the right side at full droop.
I need to add that the left sway bar bracket is off of a 93, I'm assuming theres no difference.
featherweight13 is offline   Reply With Quote
Old 10-23-2007, 10:25 AM   #2 (permalink)
Fosters I am a moderator
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
Do you have the sway bar mounted so one of the brackets is in front of the mount and the other behind it (which is the correct way)? That was one of the goofy things I remember about my install - that would would cause the bar to angled if both were either in front or behind.
Just something to check.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
Old 10-23-2007, 12:34 PM   #3 (permalink)
Avshi750
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
ya X2 on how you have the bar mounted?
also you need to get the "L" brackets on there tight so they don't twist!
where in the easy bay are you? i'm local if you need a hand and my car has this bar too.
Avshi750 is offline   Reply With Quote
Old 10-23-2007, 01:38 PM   #4 (permalink)
rex
Do your strut housings extend beyond the mounting ears? Or are they more like the front? They may be causing a problem. I'm guessing you have stock housings?
Progress prototyped the bar on a car without the extension. Similiar to this:
http://www.autozone.com/R,APP930358/...ductDetail.htm
Your rears probably looks like this:
http://www.napaonline.com/MasterPage...c+-+Right+Rear
rex is offline   Reply With Quote
Old 10-23-2007, 07:10 PM   #5 (permalink)
featherweight13
cut the fat
Yea, the left is mounted on the inside and the right is mounted outside. Rex, Im using AGXs.
Thanks for the offer Avshi. If I continue to have issues, I'll PM you. Im in Union City.
After readjusting the endlinks and tightening the sh*t out of the L-brackets the hitting has ceased. However the rear suspension feels terribly jarring and I think it has to do with them not being able to droop far enough. I'll begin to experiment. Thanks for the help everyone.
