Old 11-18-2007, 06:23 PM   #1 (permalink)
Theheadsn
Say it with DET
What are YOUR Kyb's set at?
Hey guys, I finally, FINALLY, got my suspension installed on my car, thank god.
Basically got the AGX KYBs with Road Magnets, but it kinda blows because I wanted to use the stock boot covers, had to stick with just using the bumpstops that came with the covers. Owell
But my question is, what do you guys think would be the best setting for the front and the back for a 95 b14?
Anyone with personal experience that wants to chime in, please, give me ideas. Thanks!
Another thing, I don't plan on racing my car, I want the smoothest ride possible
Theheadsn is offline   Reply With Quote
Old 11-18-2007, 06:58 PM   #2 (permalink)
TurboTank
slamed150
Trader Rating: 45 (100%)
mine are set at 4 front and 7 rear. that setting is for max stiffness. i have found if the rears are set to 8 then it doesnt move at all(very harsh). for a smooth ride i would sometimes set them to 3/5. anything under 3 will bottom out on these cars. actually they will bottom out on setting 3 if driving hard. but if the road is retalitly smooth it will be ok. the nice thing about the 4/7 i run now i dont have to slow down for off ramps(fun times)
tank
Sponsored by http://www.Ipsmotorsports.net
b14 ve turbo
b13 beater
please keep hands and feet within the gard rails and wait for the room to come to a complete stop
I will wrench for parts( I travel also). pm me
TurboTank is offline   Reply With Quote
Old 11-18-2007, 07:00 PM   #3 (permalink)
MCarp22
From: http://www.geocities.com/g_wellwood/...andstruts.html
KYB AGX Damping (this info is for B13s but it ought to be useful)
Front (4 positions)
1- OEM
2- 15% firmer
3 -72% firmer
4 - 123% firmer
Rear - 8 Positions
1- 5% softer
2- OEM
3- 7.5% firmer
4- 15% firmer
5- 43.5% firmer
6- 72% firmer
7- 97.5% firmer
8- 123% firmer
I plan on setting mine to 2 front 4 rear for street use.
Mike Carpenter
'94 Sentra LE - Ugly DD
'95 Subaru Legacy LS - fiancée's ride
MCarp22 is offline   Reply With Quote
Old 11-18-2007, 08:34 PM   #4 (permalink)
classicaddict
this foreum= FAIL
Front (4 positions)
1- OEM
2- 15% firmer
3 -72% firmer
4 - 123% firmer
Rear - 8 Positions
1- 5% softer
2- OEM
3- 7.5% firmer
4- 15% firmer
5- 43.5% firmer
6- 72% firmer
7- 97.5% firmer
8- 123% firmer
i would suggest a 3-5 setting, 2-4 will be to soft depending on your springs and will cause alot of bouncing issues, that will blow your struts out. however KYB doesnt have the highest level of quality control and the damping level is differant for each strut.
also, wrong section.
THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE
please read this link to expand on above.
Old 11-19-2007, 09:43 AM   #5 (permalink)
chris/sr/se
Snatching gold chains...
I have a B14 with AGX & RM's I use 2/4 settings... No bounce here.
We are a community!
chris/sr/se is offline   Reply With Quote
Old 11-19-2007, 10:38 AM   #6 (permalink)
TeKKiE
work in progress...
Trader Rating: 26 (100%)
AGX's w/ RM's.
2/4 settings are too soft, so I upped them to 3/5. Feels better, but still may go up a notch to 3/6.
SR20DEEP in TX
Old 11-19-2007, 12:09 PM   #7 (permalink)
ar94se-r
Pacific Blue 4Banger
2 in front, 4 in rear right now. No bounce either. It just depends on what you feal is best to you. I had to play around with the settings to match my daily drive which is ALL highway. City is different. Also, you could have cut the OE bumps off the boots and still used the boots.
AR97 SE-R
ar94se-r is offline   Reply With Quote
Old 11-19-2007, 03:01 PM   #8 (permalink)
Theheadsn
Say it with DET
We cut down the rear ones to give it more travel, but with the front, if I was going to cut it to use the ES bumpstops I had, it would have been to much. The boot cover itself would have been all over the place.
I know my rears at 4 right now, I dont know exactly what the front is, i think its 4 as well
Old 11-19-2007, 05:24 PM   #9 (permalink)
Dan9
My car is out of storage.
Trader Rating: 20 (100%)
2-4 1st gen RM springs.
I havent played with the settings yet. In front because the drop is a bit too low I will bottom out if I hit a sudden dip.
D
Looking for peace of mind
Old 11-19-2007, 05:39 PM   #10 (permalink)
XxToKeSxX
XxToKeSxX's Avatar
On the b14 for daily use:
2 in front and 1 in the rear
On the b14 for drag use:
1 in front and 8 in the rear
On the b14 for aggresive turning:
2 in the front and 7 in the rear
On the b13 for daily use:
2 in front and 4 in the rear
On the b13 for drag use:
On the b13 for aggresive turning:
2 in the front and 8 in the rear
In the b14 I am using 350/275 spring rates
In the b13 I am using 325/250 spring rates I'm pretty sure.
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
Old 11-19-2007, 06:16 PM   #11 (permalink)
rodrigo
Cookin Up Some Snails
Trader Rating: 16 (100%)
i have mine at 2 in the front and 5 in the rear.
AGX with koni bump stops and H&R springs. rides good.
rodrigo is offline   Reply With Quote
Old 11-19-2007, 07:35 PM   #12 (permalink)
nathan2284
Up Yours Toad
1 and 1 is how i roll. Except when I follow adam.
nathan2284 is offline   Reply With Quote
Old 11-21-2007, 01:03 AM   #13 (permalink)
Theheadsn
Say it with DET
Cool so far. But I know theres more people out there that HAVE the RM/KYB set up on they're b14's lol
I should have taken pictures of the whole bumpstop issue while i had everything appart. Owell
Old 12-04-2007, 01:30 PM   #14 (permalink)
Nove
Vogtland lowering spring
Has any body hear of Vogtland springs I'm planning on purchasing this combo so any help would be appreciated see link
http://cgi.ebay.com/ebaymotors/KYB-A...spagenameZWDVW
Thanks.
Nove is offline   Reply With Quote
Old 12-04-2007, 01:36 PM   #15 (permalink)
2dr_sentra
Slut Butter
Trader Rating: 31 (100%)
4 front/ 8 rear 24/7!
97 200SX SE-R w/SR20DE+T and S4 cams
2007 Versa SL 6speed
http://www.cardomain.com/ride/2035028
Xbox gamertag - ColonelYoshi
Old 12-04-2007, 09:25 PM   #16 (permalink)
reverm
Captain Slow
Most mass produced adjustable twin tubes have large variances in damping. Koni is particularly notorious for having horrible variances on all of their dampers off the shelf (this includes some of their cheaper race dampers, like the 8611).
Captain Slow.
Old 12-04-2007, 10:40 PM   #17 (permalink)
GA16Lucino
rockin the 1.6
i've been dd'ing my b14/RM/AGX setup at 2/4 and its quite nice. Not too floaty, not too darty. It will bottom out if you're not careful though.
GA16Lucino is offline   Reply With Quote
Old 12-04-2007, 10:56 PM   #18 (permalink)
skeeter149
Tryin' To Be Like You
uh sounds like when the raxles get here and i put the rm and agxs in its gonna be like 3 front 6 rear for me. keep the list coming cool to see what people are using.
Originally Posted by Shawn B
Purple monkey Fritos elbow dishwasher cigarette can-opener!
Acorn lug-wrench carpet vibrator Gatorade?!?
i am about to make that my sig shawn if you will allow it?
hell i did it so if you want me to i can get rid of it but i thought it was hella funny
skeeter149 is offline   Reply With Quote
Old 12-05-2007, 12:26 AM   #19 (permalink)
t bags
agent camel toe
agx's mated to g/c--1f/2r for that caddy-like ride and 4f/7r at the track--even on the soft settings she handles great on corners..it could be the 325f/250r g/c springs
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 12-05-2007, 12:51 AM   #20 (permalink)
sr20monkey
classic lover
agx w/ hyperco gen2 on b13 2/4 for daily driving 4/8 in the curves on the weekends
White/black u13 powered 94 se-r
Maroon 93 5th pop-out (sold)
sr20monkey is offline   Reply With Quote
Adv
