........what? i have no clue what is being asked. is it that you want to rase the car a 1/2 inch? i know some places carry universal spring spacers.
__________________ THIS FORUM HAS BEEN AROUND SINCE 2000........TRUST ME WHEN I SAY YOUR QUESTION HAS ALREADY BEEN ASKED. SEARCH BEFORE YOU POST....PLEASE please read this link to expand on above.
Get the rubber inserts from nissan that go under the spring. They rise it up about .25" IIRC. Why do you want to raise the spring perches?
I need more suspension travel because my car is too heavy. I don't like coil overs because they are only 8'' and my springs are 14'' so I believe they give smoother off road ride.
Force of spring = spring rate * distance of compression.
So if coilovers have less distance to compress, spring rates must be higher to apply the same force as regular springs.
I'd like to use metal spacers so I don't have to worry about cracking of rubber spacers. Can I just buy universal metal spacers?
What I was thinking about is cutting off stock spring perches from struts and putting them on the top of AGX's perches. Then drill through both perches and bolt them together.
Thanks for pointing this out. You misspelled your sig too. There is no such word as "shawn" it is supposed to be "shown" - the past participle of the verb "to show."
You can probably get softer 14" springs for coilovers.
Originally Posted by SmilyFace
If I put AGX to 1st setting are they going to be softer than OEM? I need softer struts than OEM and that is why I want to put AGX.
They are supposed to be "slightly softer" in the front, the same as stock in the rear. I'd imagine even then they'd actually work out to be stiffer than stock. I'd look for like a monroe sensatrac if you want softer.
I am going to be driving off road with some heavy sh*t on daily basis....
Why not a pickup truck then?
Mike Carpenter
'94 Sentra LE - Ugly DD
'95 Subaru Legacy LS - fiancée's ride
there is a name shawn
whats up with these spacers I want to raise the rear of my b13 will they work, and be safe? where can I get some?
If I hadn't pointed it out Smilly, someone else eventually would have.
wow can someone please give smilyface a answer this whole thread just made my brain hurt, every response i wished for a answer and instead got a riddle. who cares what he wants to haul even if its dead donkeys, just give him a answer or tell him you cant help. look this thread even made me crazy now i wanna go find a purple donkey put it in my trunk and call it a boozaka tube
Originally Posted by Shawn B
Purple monkey Fritos elbow dishwasher cigarette can-opener!
Acorn lug-wrench carpet vibrator Gatorade?!?
i am about to make that my sig shawn if you will allow it?
hell i did it so if you want me to i can get rid of it but i thought it was hella funny
LOL at how he wants you to change ur name to shown! I was just searching for more of this dude's posts and gosh darn it I knew I was gonna find some funny stuff.
There is a small error in your chain of logic.
The free length of the spring is not directly related to the amount of travel you have in your suspension system.
Part of it is because the actual travel of the spring is the loaded length (or free length) minus the coil bind height. In other words, a spring with a 14" loaded length and a 12" coil bind height will have less travel than a spring with a 8" loaded length and a 4" coil bind height.
This is a moot point though, because (in a properly designed system) the damper will always run out of travel before the spring reaches coil bind. Basically, it doesn't really matter whether you choose the 8" spring or the 14" spring, because you are going to hit your bump stops before your spring turns stacks down into a solid spacer regardless.
So from a practical standpoint, you should be looking for springs with a low spring rate and sufficient free length to match up to the dampers with the most travel.
If you're on a budget, I would say stick stock springs on a new set of GR2's with some polycellular bump stops (Konis or something of the sort). It won't let your car rock crawl, but it will be tolerable both on tarmac and rocky gravel.
