Old 12-09-2007, 08:59 PM   #1 (permalink)
JKho
Track season is starting
Trader Rating: 23 (100%)
Interpreting shock dyno
Hi everyone,
Can someone help me interpret this shock dyno graph?
They are from a company called F2 and are supposedly big Honda supporters but are expanding their lineup into Nissan's, Toyota's and others. The stock springs are 4kg fronts and 6kg rears and are 18 way adjustable.
I just have no idea what the shock dyno is saying. Is this good/bad?
Thanks.
JKho is offline   Reply With Quote
Old 12-09-2007, 09:53 PM   #2 (permalink)
MCarp22
Shock dynos aren't quite as easy as car dynos to interpret.
Basically, as the chart goes to the left, the slower the shock is moving. So the left side represents how stiff it is when you're transitioning into a corner, and the right side represents how stiff it is when you hit a bump.
The bottom half represents the compression stiffness, The further it goes down from the middle of the graph, the stiffer it is when the shock compresses.
The top half is the rebound stiffness. The further up you go from the middle the stiffer it is as the shock extends.
From what i can see there, rebound is about as stiff as an AGX set to 4/8 and it gets considerably stiffer than an AGX as the piston speed increases.
The compression is a *lot* softer than an AGX.
I'd imagine these would suck on the street with the rebound being that stiff at high speeds. It would probably plant the car on the bumpstops if you were on a rough road or something.
Mike Carpenter
'94 Sentra LE - Ugly DD
'95 Subaru Legacy LS - fiancée's ride
MCarp22 is offline   Reply With Quote
Old 12-09-2007, 10:14 PM   #3 (permalink)
MCarp22
To elaborate, here's the same shock compared to a an AGX and a Koni Sport (yellow):
Old 12-09-2007, 10:36 PM   #4 (permalink)
reverm
Captain Slow
A little context may help us interpret this for you. Which chassis is this for, and is that a front or rear damper?
Captain Slow.
Old 12-09-2007, 10:54 PM   #5 (permalink)
MCarp22
Judging by the heading there it's a 1st generation MR2. Couldn't find anything to suggest front or rear though.
Old 12-09-2007, 11:09 PM   #6 (permalink)
98sr20ve
Is the shock even adjustable?
Steve
06 G35 6MT
Old 12-10-2007, 12:54 AM   #7 (permalink)
MCarp22
They're supposed to be "18 way adjustable" but the dyno only shows a single setting.
*edit* a friend of mine says when he was researching colovers, some of them really were "18 clicks and no adjustment" o_O
Old 12-10-2007, 07:36 PM   #8 (permalink)
98sr20ve
Just from looking at the dyno it's nothing to get excited about. Dyno's only tell you a small part of the story. Very small part. Proof is in the results. We have good options already for all our cars.
