Old 01-09-2008, 03:38 PM   #1 (permalink)
james23nyc
G20 DET
Wrong axle installed causing problem?
ok, originally had an LSD tranny in my non-touring G20, or so I thought by what was told to me, and what Infiniti tried to tell me when I when i was trying to get axles...got a new tranny about a year and a half ago, that was supposed to have been LSD, also took a few days longer for the company to find it, so they sent it to my mechanic, they installed it, but when I did my DET swap, i needed new axles....so i ordered a passenger side axle for an LSD tranny, my mechanic got the driver's side, because later on, it was discovered that I needed a driver's side as well, well after going on APG military base and working on my car, we put in on the lift, one wheel rotates, no bulge on the driver side of the tranny, when u turn one wheel in one direction, the other wheel turns the other way, meaning NO LSD TRANNY!!!!!......now my question is, if you have an LSD axle of the passenger side of the tranny, what will happen? will something bad happen? I am getting a click and knocking sound from the rigth side of the car that only occurs when the car is on the ground moving, not in the air on the lift while pressing the gas....i thought the driver's side was the only side that mattered when it came to axles and LSD/non-LSD?
'96 G20-SR20DET/5spd swap/K-Sport Coilovers/Custom FSTB/Octotat RSTB/Walbro 255lph/N60 MAF/Calum Ecu/AFPR/Skunk2 3in muffler/3in catless exhaust/Autometer Boost Gauge
james23nyc is offline   Reply With Quote
Old 01-11-2008, 02:35 PM   #2 (permalink)
myprojectB13
myprojectB13's Avatar
Trader Rating: 16 (100%)
Passenger side is the same for both LSD & non-LSD.
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 02-08-2008, 02:14 PM   #3 (permalink)
busyman_88
hey im having the same problem actually any word on this at all. i could use some help with this to.
busyman_88 is offline   Reply With Quote
Old 02-08-2008, 02:30 PM   #4 (permalink)
jer_760
Broke Ass
jer_760's Avatar
Passenger side is interchangable, but don't you have to have the matching axle bracket for whichever axle you plan to use? lsd axle has to have lsd bracket, non lsd axle has to have non lsd bracket?
95 200sx
sr20ve
Old 02-12-2008, 03:41 AM   #5 (permalink)
busyman_88
is this true would it make it knock, well i put g20t axles in my nx2000 when i did my five lug conversion so i would have a lsd bracket then.
