Old 02-23-2008, 05:58 PM   #1 (permalink)
zer099
Red Emblem
Whiteline LCA Brace Question
Ok, so I got myself a whiteline LCA brace. Got the one for the RNN14 since everone seemed unable to say that if the B13/B14 brace would clear a 3" DP, plus only he had the RNN14 brace at the time. Got it, mounted up and desided that it sits way to low:
4" is not a lot of room. But, I did notice that I had about an 1" between the brace and the DP. So, question is this: Will a B13/B14 whiteline LCA brace clear a 3" DP? If the B13/B14 model gives you about .5" to an inch more clearance then that would still clear my DP, and that would rock. Anyone, any help would be nice.
Note: No I cant fit a 3 point brace under there (progressive or cusco). Also, for you big suspention gurus, if you think the 4" will be fine, let me know. I am running AGXs with RMs GenII right now. Might switch to Konis in the future.
-98' 200sx GTi-R, FMIC, 3" downpipe/cat/piping/ and muffler, and some other bells and whistles
-96' B14 left stock for the daily drive... also expired
-95' S14 soon to be RB26ed once I get off my ass
-91' S13 w/ SR20DET black top... expired
-89' B12 SE... expired
zer099 is offline   Reply With Quote
Old 02-23-2008, 10:11 PM   #2 (permalink)
turbofied
L337 VVL
Take it for a drive you will find that because it sits almost inbetween the front wheels that it is very hard to scrape it on anything. Mine gives me pritty much no greif.
Neo forums wants you!:thumbsup:
www.neovvl.org
turbofied is offline   Reply With Quote
Old 02-24-2008, 12:00 AM   #3 (permalink)
zer099
Red Emblem
I would, but I don't want to mark it up. That would pretty much void being able to return it.
Old 02-24-2008, 12:51 AM   #4 (permalink)
JKho
Track season is starting
Trader Rating: 23 (100%)
Post #6 - http://www.sr20forum.com/general-sr2...brace-b13.html
JKho is offline   Reply With Quote
Old 02-29-2008, 12:36 AM   #5 (permalink)
DALOCSR20
it clears the downpipe fine but the rear arm of the controll brace hits my 3in piping. IT fits but its tight!!!!!!!!!!
DALOCSR20 is offline   Reply With Quote
Old 03-06-2008, 09:07 PM   #6 (permalink)
akchang
i got AWD so let it snow!
i have a GTIR with the 3" downpipe clearing whiteline LCA brace. the front suspension is almost identical to the B13 and mine scrapes pretty dang hard when i bottom out the suspension at high speeds over dips in the road. also i have to be VERY slow when rolling over gutters. im lowered about an inch and a half on tein HA coilovers. my wheels are 15x8 with 205/50R15 rubber. my brace is even closer to the ground than yours. what size wheels and tires are you running? from this i could probably tell you if you will scrape or not. the brace is the only aspect of my suspension setup that hinders the everyday drivability of my car and it kind of pisses me off. im contemplating losing the brace as it is a pain in the ass to have to worry about it scraping but then again i come from 4wheeling and im used to having clearance. i guess its the price you pay for good handling.
akchang is offline   Reply With Quote
Old 03-07-2008, 12:51 AM   #7 (permalink)
zer099
Red Emblem
I have 205/40 R17s right now. I sent that brace back and got a B13 whiteline brace. Hugs the downpipe now but doesn't touch. So I think I'm about as good as it can get. I expect to scrape some, but since i switched from a N15 brace to a B13 one I gained back about an inch more travel.
For all you searchers out there in the future, YES, a whiteline LCA brace will clear a 3" downpipe. (This is on a B14, so the B13 should be the exact same) I will get some pics up tomorrow so people can look at the diffrance between that n14 brace and the B13/B14 brace clearance.
Old 03-07-2008, 01:27 AM   #8 (permalink)
SLEEPIN-SR-2@
squaadd up!
For all you searchers out there in the future, YES, I whiteline LCA brace will clear a 3" downpipe. (This is on a B14, so the B13 should be the exact same) I will get some pics up tomorrow so people can look at the diffrance between that n14 brace and the B13/B14 brace clearance.
i have a whiteline brace with a 3inch turbo back in my b13 it clears fine. no problems
-Jason
2007 toyota tundra- daily/towtruck
1993 sentra SE-R - vvl swapped
2007 suzuki LTR-450R
2007 kawasaki prarie 360 4x4
2006 acura rsx type s- full bolt ons -SOLD
2006 honda cbr600rr-sold
SLEEPIN-SR-2@ is offline   Reply With Quote
Old 03-12-2008, 05:28 PM   #9 (permalink)
akchang
thats great to hear! get those pics up so we can see the difference. if the normal B13 brace will clear the 3" DP then i will gladly switch over as im tired of scraping.
Old 03-13-2008, 07:21 PM   #10 (permalink)
zer099
Red Emblem
Right, so here is an updated picture of the B13/B14 brace on the same car:
If you notice there is like 1/10 an inch of space between the brace and exhaust. Much nicer.
*NOTE: I have no clue how the hell y car got an inch shorter. I went from sportline springs to RM... the sportline have a 1.9 inch drop, the RM have a 1 inch drop. The car looks visably .9 inch taller in the wheel well, but some how the chassis droped an inch... and I am freaked out about it. At least the brace is as tight to the exhaust as I can get now.
