Old 03-26-2008, 07:18 PM   #1 (permalink)
federicov
sr20owner
CSK adjust
hi everyone, anyone know how i adjust my CSK whit koni reds insert is for B13/14
thanks
federicov is offline   Reply With Quote
Old 03-26-2008, 07:48 PM   #2 (permalink)
Pretty White
newbie
Pretty White's Avatar
1st question, do you really have CSK's or are you just asking in general?
TEAMSERIOUS 2008!
Old 03-26-2008, 07:59 PM   #3 (permalink)
federicov
sr20owner
yes i have.
Old 03-27-2008, 07:52 AM   #4 (permalink)
squirlz
Come get your ham Tina!
Press and turn
It seems that some people have been spoon feed their whole lives, It is societies job to teach them how to use the spoon for themselves.
squirlz is offline   Reply With Quote
Old 03-28-2008, 05:29 PM   #5 (permalink)
RE-Spect
Out of business
Trader Rating: 38 (100%)
thanks
Press the piston down, till you feel if falls into a groove. Once it is set in the groove turn all the the way counter clockwise(fully hard setting), until it does not turn any more,while still holding it in the groove turn 1and1/4 turns clockwise.This setting should be good enough for the street, that's what i am running. I have the Maxima's up front and the b14 inserts in b13 housings in the rear.
In Loving Memory of ZAD,We LUV Ya ta Death, Save us a Spot Next To Ya Up There, we'll see you soon
He can make 200,250 or even 300whp! Because at the end of the day, He's not going no where but up and down Liberty Avenue stuntin for the rest of his fellow Indian friends!
If ya want JDM go the fu_k to Japan
4Doors and not 2 are the real Sunny's
RE-Spect is offline   Reply With Quote
Old 03-28-2008, 08:17 PM   #6 (permalink)
federicov
sr20owner
and how you pullout the piston?
Old 03-28-2008, 08:40 PM   #7 (permalink)
veilside180sx
98 SE
Remove the strut from the vehicle and bottom out the strut shaft into the housing (follow the rest of Respect's directions)
You don't pullout the piston, you push the strut shaft straight down into the housing.
Koni www.koni-na.com
www.nissanroadracing.com
Old 03-28-2008, 09:23 PM   #8 (permalink)
federicov
sr20owner
yes, but after i push the piston how i pull out?
Old 03-29-2008, 03:10 AM   #9 (permalink)
veilside180sx
98 SE
It will slowly come out by itself, or you can pull on the strut shaft to get it to return.
