Master cylinder question - SR20 Forum
Old 09-18-2008, 09:16 AM   #1 (permalink)
I'm looking to upgrade my master cylinder to a 1'' or even bigger if possible..
Any suggestions as to which I could use?
Thanks
Ward20 is offline   Reply With Quote
Old 09-18-2008, 09:27 AM   #2 (permalink)
Drivin' my life away. . .
Why?
"If everything seems under control, you're just not going fast enough." - Mario Andretti
Old guy is offline   Reply With Quote
Old 09-18-2008, 09:40 AM   #3 (permalink)
i'm upgrading to some 4 piston calipers up front and the bluebird rears..
I have a 1993 nissan GTS, so i wanted more clamping force with less pedal effort
Old 09-19-2008, 08:46 AM   #4 (permalink)
Pressure = Force/Area
So, bigger area means less pressure for the same applied force. However, at the wheel cylinder, Force = Pressure x Area. You will get more clamping force with the larger 4 piston area even if the pressure is lower. What is more important is the balance between front and rear braking.
Old 09-21-2008, 02:40 AM   #5 (permalink)
Captain Slow
Feedback Score: 4 reviews
Increasing your MC bore will reduce the resultant pedal travel back to reasonable levels, albiet at the cost of increased pedal travel.
Look for an Altima MC. U13 chassis, is the one that swaps direclty onto the B13/B14 chassis, if I remember correctly.
IMG - The Independent Motorsports Group
Cars - Competition - Camaraderie
Old 09-22-2008, 03:24 PM   #6 (permalink)
Thanks guys
Old 11-01-2008, 10:39 PM   #7 (permalink)
I have stock MC with 6 piston willwoods with bigger rears also and im stopping fine, if I upgrade I think ill lock up so there is a little pedal play
Buddy is offline   Reply With Quote
