Camber Plates for Tein coilovers on a B13 - SR20 Forum
Old 10-09-2008, 11:53 AM   #1 (permalink)
NISMO rules
Hi I just bought a set of tein Super Street Coilovers no camber plates comes with these for the B13 what options are use for camber plates Cusco or something else
Thanks
enoehttemi is offline   Reply With Quote
Old 10-09-2008, 12:01 PM   #2 (permalink)
Tired!
coach's Avatar
Feedback Score: 43 reviews
Tein! Ground control might work.
Brent
1999 SE-L -- back to NA form
Old 10-09-2008, 01:59 PM   #3 (permalink)
NISMO rules
Brent
I think i saw someone trying to mate Ground control with tein but it didn't work
Old 10-09-2008, 05:18 PM   #4 (permalink)
Feedback Score: 12 reviews
Tein or get a straight spring that will fit the GC and the TEIN. Tein springs are not straight so they need a custom tophat/camberplate,.
Steve
06 G35 6MT
Old 10-09-2008, 05:20 PM   #5 (permalink)
You're Ugly!
Feedback Score: 18 reviews
i have heard that b14 camber plates work on the b13 tein set.
SR20DEEP CA
shingouki1 is offline   Reply With Quote
Old 10-09-2008, 05:35 PM   #6 (permalink)
http://www.tein.com/products/standar...rice_list.html
http://www.tein.com/price/nissan.html
It appears that the B13 uses a 65mm front spirng and the B14 uses a 70mm spring. Straight on both. I thought they were tapered. I am almost sure that they were not in the past. All it would take is a small redesign to change it so maybe they did that. In the end a straight 65mm front spring should work fine with a GC Camber Plate. Call them. The bigger problem is the special nut that GC needs to provide to interface the Camber Plate with the shaft of the strut. If they don't make that nut your screwed
Old 02-07-2009, 08:47 PM   #7 (permalink)
Control before Power
Feedback Score: 3 reviews
Ground Control sent me the right size nut when I got my Tein SuperStreets. You just need to let them know what size you need. I think the nut size was M12 X 1.25. They also have different size top hats depending on what you want/need. Call them,they won't design your suspension for you but if you know what you want they can come up with the parts.
NI SER-1 is offline   Reply With Quote
Old 02-11-2009, 01:55 PM   #8 (permalink)
SE-R Geek / Nissan Tech
The tein B14 ones work perfectly.
i know cause i have them
the only thing is you have to clearance the hole in the strut tower to get the full range of adjustment. its no more than a half inch iirc (car isnt in front of me....its parked away for the winter). if you have a FSTB it makes up for the minor possibility of weakening the tower.
92 SE-R Autocrosser "BRE" tribute
71 MGB GT "The Great Pumpkin"
07 Frontier SE Nismo
