rubbing or no rubbing 16X7 40mm off set on B14 - SR20 Forum
Old 12-30-2008, 07:04 PM   #1 (permalink)
Feedback Score: 4 reviews
hey guys, found some cheap MB wheels, brand new, but not sure the fitment
16x 7 with 40mm off set, will the 205X50 16 tires rub the inner struts?
thanks
Where are you hurting today?
blkbird is offline   Reply With Quote
Old 12-30-2008, 09:19 PM   #2 (permalink)
Feedback Score: 20 reviews
Previously i had 17x7 w/ +40 off set and had no issues either. I think the highest offset i used on a B14 was +42? Currently I am running 16x7.5 w/ a +32 offset w/ 205/50/16 and have no rubbing issues. I wish I went w/ 225/50/16 instead.
Diabolic Hippo is offline   Reply With Quote
Old 12-30-2008, 11:27 PM   #3 (permalink)
Thanks Diabolic Hippo. Mine is a 200sx on stock suspension. I sort of getting use to the 15 stock height, will it jack up the car like 4x4 by goin 16s.
So the tires, 205.50 should be OK.
Old 12-30-2008, 11:47 PM   #4 (permalink)
FSU
Feedback Score: 6 reviews
You will be fine. I run 205/45/16 w/o rubbing.
On a B14 there is enough room for a 17X8 wheel with 225 tires.
donshou is offline   Reply With Quote
Old 03-10-2009, 04:36 PM   #5 (permalink)
NXR Turbo User
I changed the stock alloy on my B13 for some 16" ones and one of the tyres was rubbing. I found out it was the strut being bent that was the problem. I have had N14's and B13's with 14", 15", 16" and 17" rims without any other dramas.
Built not Bought!!
SR20pulsar is offline   Reply With Quote
Old 03-10-2009, 04:52 PM   #6 (permalink)
FSU
You will only rub the 16X7 40 offset on B14 at full lock.
You can fit a 17 X 8 w/ 225 width tires on a B14. Don't worry about the rubbing.
