Det engine mount problems - SR20 Forum
Old 01-03-2009, 12:50 AM   #1 (permalink)
boost junkie
The motor I received from tiger japanese was an automatic and I have a 5 speed. Only the rear mount is bolting up. Is this because the engine is a automatic and my car is a 5 speed? Will some jgy mounts fix this problem or is there a better route to go?
SideCar is offline   Reply With Quote
Old 01-03-2009, 12:59 AM   #2 (permalink)
boost junkie
Or would a set of automatic mounts work?
Old 01-03-2009, 01:00 AM   #3 (permalink)
banned
Feedback Score: 5 reviews
auto or manual the engine is the same. only the tranny is different. are u using the auto tranny or the manual tranny? everything should bolt up perfect if ur using a 5speed tranny.
madoutb13 is offline   Reply With Quote
Old 01-03-2009, 01:05 AM   #4 (permalink)
boost junkie
I have a 5 speed trans. Only the rear engine mount is bolting up
Old 01-03-2009, 01:55 AM   #5 (permalink)
Weekend Warrior
Feedback Score: 60 reviews
^You drive a P10 or P11? You suppose to use your existing motor mounts. There should be NO motor mount issue. The motor is the motor. There is no auto motor or manual motor. As madoutb13 mentioned, the tranny decides that for the car. Where are your existing motor mounts?
Bend But Don't Break
Old 01-03-2009, 02:18 AM   #6 (permalink)
boost junkie
Yes I drive a p10. Now I am thinking I have aftermarket mounts. The front motor mounts sits where the turbo is. And the rest just do not bolt up.
Old 01-03-2009, 12:11 PM   #7 (permalink)
working on it
swiss's Avatar
Feedback Score: 27 reviews
OK, you said the rear bolts up. On the passenger side, you need to use the mount and mount bracket from your old motor. Your transmission mount should bolt up as well.
The front mount you're going to have to figure something out:
http://www.sr20forum.com/turbo/186625-motor-mount.html
Old 01-05-2009, 11:39 PM   #8 (permalink)
the jgy mounts are just painted factory mounts.
1998 se-r built w/gt3076r
serturbo98 is offline   Reply With Quote
Old 01-09-2009, 10:47 PM   #9 (permalink)
wants 2 dry hump chriscar
Feedback Score: 8 reviews
automatic cars have no front dog bone mount and the dimensions of the rear mount are different. everything bolts up the same but if you try to press prothain mounts into the rear automatic mount its going to be too small.
Old 01-09-2009, 10:49 PM   #10 (permalink)
p10 motor mounts are differant than b13 mounts so you are going to need to do some searching on this as the engine you bought likely has b13 mounts on it. go to g20.net
Old 01-20-2009, 09:52 PM   #11 (permalink)
sell out
Pics would help. Im almost 100% sure the p10 and b13 mounts are the same. The fact that the engine had an auto tranny is irrelivent. I've never in my 50 or so motor swaps, b13 or p10 had an engine not go on its mounts.
AWD & BOOST.... FTW!!!
b13autobot is offline   Reply With Quote
